Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-02-2005, 01:18 AM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
Altitude and boost?
Since atmospheric pressure is 14.7 at sea level and more like 11.7 at 5,000 Ft elevation, would'nt the first 3 PSI of boost go to waste? Well, not go to waste, but if you're somewhere where the atmosphereic pressure is 11.7, would'nt the first 3psi of boost do nothing but fix the elevation differeance (while adding power)
I have another question, theres this 'rule of thumb' I heard about that says you lose %3 of power for every 1000FT of altitude, do you guys think this is true?
My third question, let's say you have a 100 HP all motor engine and you go to a really high altitude, high enough that your engine makes more like 70 HP... if you boosted your motor to add only 30 HP and ended up having 100 HP at that high altitude, would the engine be reliable as stock since it's making only 100 HP?
EDIT: I'm not 100% sure if atmospheric pressure at 5000FT is 11.7, so if you know the correct pressure, please correct me.
Old 01-02-2005, 01:42 AM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
well if your at 5,000 ft elevation and if the air is usually alot colder than sea level areas you could be making more power because of air density... but yea you do loose power at higher altitudes, and a turbo can make up for the atmospheric pressure difference and then sum. I would suspect reliability would be the same.
I disregard my perceived image in the persuit of knowledge.
Old 01-02-2005, 11:20 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Altitude and boost?
The first 3 psi of boost would bring you back to sea-level performance. However, all turbos limit their boost pressure. This limit is dependent on a pre set limiter (in the old days it was a 'wastegate') So long as the turbo spins fast enough to develop full boost then you will not experience any performance loss due to altitude.
This is why piston powered aircraft work very well with turbos.
Old 01-02-2005, 12:47 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Yes a lot of the time turbos function as equalizers on aircrafts. At 5000ft, barometric pressure is 24.9 in. HG according to Hugh MacInnes. Using the pressure ratio method of
(14.7+PSIG)/14.7
I did 13.7/14.7 and got 0.93. Looks like you lose like 7% for each psi of atmospheric pressure loss.
It may be slightly less reliable due to heat created by compression. With an intercooler, you're looking at about the same reliability.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 01-16-2005, 05:15 PM
SaabJohan SaabJohan is offline
Power is lost when air pressure goes down. At an altitude of 4000 m i think you lose something like 30% of the power.
Most modern turbocharged engines compensates for this loss by increasing boost pressure. This does however increase turbocharger speed so there are limits for this compensation.
Old 01-17-2005, 08:20 PM
TRD2000's Avatar
TRD2000 TRD2000 is offline
isn't this why saab and volvo started using "low pressure" turbos?
Who needs AWD? i feel inspired by the original 911 turbo, my car will have more rubber sqeezed in its ass than Annabelle Chong! and it will go down as one of the greatest rides in history!
Old 01-17-2005, 10:31 PM
psychorallyfreak's Avatar
psychorallyfreak psychorallyfreak is offline
Send a message via ICQ to psychorallyfreak Send a message via AIM to psychorallyfreak Send a message via MSN to psychorallyfreak Send a message via Yahoo to psychorallyfreak
huh?
"Boost" is defined as the pressure above atmospheric pressure, no matter the elevation.
Old 01-18-2005, 04:17 PM
Re: Re: Altitude and boost?
Low pressure turbos are mainly used to increase torque, but they also increase top end power slightly. The idea was to deliver a drivable engine with a low fuel consumption.
Early low pressure turbos wasn't equipped with any electronic boost controlling devices.
Today the engines use a torque demand engine management system which can see to that the engines are delivering the same torque output even if the car is driven at low or high temperature in cold or hot weather. The systems also compensate for things like alternator and AC compressor load.
