Old 01-01-2005, 10:56 PM
CamaroFan CamaroFan is offline
starting engine prob
my 95 3.4L camaro is sluggish about starting up.
i replaced the battery which was bad and it help the car to turn over faster, but it still has a little bit of sluggishness.
what could it be?
Old 01-01-2005, 11:38 PM
whoisdabomb86 whoisdabomb86 is offline
Send a message via AIM to whoisdabomb86
ive seen starters do that on v8's where they dont turn fast, it could be that but then again who knows about a 95 v6 this was a 80's 350. i think about starting there.
Old 01-02-2005, 12:44 PM
justlearning justlearning is offline
Send a message via AIM to justlearning
Re: starting engine prob
before u go spending money on a starter first check out the more common cheap fixes, check the wires and battery terminals for corosion or worn spots and check to make sure none of the wires might be grounding out somewhere if theres a knick in them
Old 01-02-2005, 02:11 PM
NINÅ's Avatar
NINÅ NINÅ is offline
Jump!
A good tip justlearning. Also, he can use a heavy
gauge wire to temporarily jump the starter to the battery.
( WATCH OUT FOR MOVING PARTS )
This will, in an instant check all those places you mentioned,
even if some of them are difficult to get to.
If it cranks better using the jumper,
he then should renew all those connections.
REFUSE
. . TO . . LOSE
Old 01-02-2005, 02:12 PM
brentp brentp is offline
if you have advanced the timing at all i can cause it also
Old 01-02-2005, 04:11 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
if you go to the dealership, they can use a diagnostic tool to check your battery, starter, and charging system to see if there are any faults in your circutry.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 01-03-2005, 07:31 PM
well thats weird i try to help w/ your problem then a couple days later my car wont start, i think it was the starter solinoid but that part costs like thirty some bucks and the starter and solinoid both was only sixty some w/ a lifetime waranty, i just got through puttin it in and it turns over like a champ
