Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 01-01-2005, 09:48 PM
oldtheoden oldtheoden is offline
2000 xls keyless programming instructions
I did it too. Bought a keyless remote for my 2000 Avalon xls off ebay. It was suppose to come with directions, but didn't. Does anyone have them? I have instructions for programming a 2002 Avalon. Will these instructions work? thanks.
Old 01-02-2005, 07:59 PM
Re: 2000 xls keyless programming instructions
Never mind....
I found the directions. Here they are and they work perfectly.
Toyota keyless remote programming instructions
Programming:
1)Driver's door open, all other doors closed, key removed from ignition
switch.
2)Insert key into ignition switch, then remove it.
3)Press LOCK and UNLOCK on the vehicle door lock control switch at 1 second
intervals 5 times.
4)Close and re-open driver's door.
5)Press LOCK and UNLOCK on the vehicle dorr lock control switch at 1 second
intervals 5 times.
6)Insert key into ignition switch.
7)Switch ignition ON and OFF once to program a remote transmitter code
whilst retaining the original codes or twice to program a remote transmitter
code whilst erasing the original codes. Three times to check how many
remote transmitters are currently registered or five times to erase all
registered codes.
8)Remove key from ignition switch:
a)System should now lock unlock vehicle. Once , twice or five times
depending which mode has been selected. One to four times, slowly to
indicate number of remote transmitters registered.
9)Press and hold remote transmitter LOCK and UNLOCK buttons, together.
10)Press LOCK remote button for 1 second:
a)System should now lock and unlock vehicle once to confirm, twice to
indicate registration has failed.
11)If required repeat button procedure to program remaining remote
transmitters.
NOTE: To exit programming mode: Close driver's door or insert ignition key.
NOTE: A maximum of 4 remote transmitters can be programmed.
Old 04-11-2005, 10:59 AM
horstow horstow is offline
Hi
Do you have any directions for the other programming that can be done with this system. I have a 2000 Avalon XLS also and want to change the door locking/unlocking settings.
Thank!!
