Old 01-01-2005, 09:16 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
intake question
for a gst.... which is better...
the K&N FIPK, like on http://www.overboost.com/obs/product.asp?pid=12620
or get the Dejon 2g Curved Intake Pipe (sizes 2.75" 3" 3.5" & 4") Use this with Side Mount and Front Mount IC's and a 2gMAS before the turbo on http://www.dejontool.com/DSM%202gC%20Intake.htm
since im not currently boosted, but i have a feeling i will be very soon, im just doing some homework on what to start modding when i get it.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 01-01-2005, 09:25 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: intake question
Home depot intake with a K&N filter from summit racing. Cheap and it works just as well. If you can't make one yourself just get a cheapo ebay pipe.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-01-2005, 09:26 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: intake question
The filter kit is what I have and for the intake pipe I would just go to Home depot and buy some PVC piping for less than $10 and make your own!
Old 01-01-2005, 09:29 PM
ok, but say i would rather spend the money, and not do the Home Depot pvc pipe, what would be the next choice
thanks
Old 01-01-2005, 09:32 PM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Re: intake question
the K&N FIPK,
answer is both, best thing to do is get a hard intake pipe of some sort (dejon tool being a nice one) and puting a nice open air filter on the mas (K&N FIPK being one of the best) another option is getting an Injen intake system that comes with the hard intake pipe and a filter, but its expensive.
both will work about the same (many wars fought over this so no flames) the best thing is the open air filter, second is the hard intake pipe, but a pipe is realy a pipe.
Something new is coming...
Old 01-01-2005, 09:37 PM
so the K&N FIPK would fit on the Dejon pipe?
Old 01-01-2005, 09:40 PM
george536's Avatar
george536 george536 is offline
Re: intake question
yes they do go together, its not really going to connect with the filter because the pipe and the filter do not touch.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 01-01-2005, 09:43 PM
ok thanks guys
Old 01-02-2005, 08:38 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: intake question
You are asking what's better, an air filter or an intake pipe? Get them both, and if you need to buy a real intake, but remember its a piece of pipe.. buy the cheapest.. dejon.
Old 01-02-2005, 09:17 PM
4G63t Power 4G63t Power is offline
Re: intake question
Where can I get instructions on how to make the "home depot intake". Im gonna do it, but I cant find a site that has the piping sizing and parts I would need to buy. Thanks guys.
AWD sold
New car*
90' Eclipse Gs-T
Shaved head with rebuilt motor
Slowboy racing limited slip
compression 165 across the board (:
Fully ported Big 16g with 34mm flapper
Precision racing Fmic
Slowboy Boost controler set at 15lbs
Custom 3 inch turboback
Fully ported o2 housing
Ported 2g manifold
Slowboy racing UICP
3 inch hard intake pipe
SAFC
Autometer carbon fiber gauges
Putting down a solid 300whp
1/4=13.7 at 109
That mph is good for high 12's with traction (:
Old 01-02-2005, 09:28 PM
TreeFrog's Avatar
Re: intake question
if you want a cheap pipe you can get one off ebay
Old 01-02-2005, 09:29 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: intake question
I believe my site still has info on the Home Depot intake. www.posracing.net
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
