Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 01-01-2005, 09:11 PM
raynstacy raynstacy is offline
Wheel lock key
We just purchased a 03 Xterra xe 4x4 with the 16" alloy wheels. I just wanted to know if this trucks' wheel locks came with them from the factory. I checked all 4 wheels and noticed the locks on 3 and the 4th was missing. Checked under the floor carpet but no key and was also missing the rack tool and car manual. Even went as far as dropping the spare but no key. Do all xterras use the same key or are they different for each vehicle? Need to call the dealer to see if they got it but i highly doubt it. Will it need to be rekeyed?
Thanks!
Old 01-02-2005, 11:33 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Re: Wheel lock key
Xterra's don't come with wheel keys standard. Nissan dealers carry them and you'll probably need them to give you a full set as partials aren't sold AFAIK. Your dealer will have a box of keys to take off the ones on your truck since you don't have the lock and there are about 16 different varieties.
Since this is a new truck (right?) they need to give you the rack tool or you can't remove and clean underneath it (a lot of gunk gets under there and will damage your paint over time). A manual should definitely come with your truck.
If that truck is new, the dealer sounds pretty incompetent.
Xterra4x4.com and the Xterra Offroad Webring
Old 01-03-2005, 07:17 AM
Re: Re: Wheel lock key
Thanks for the reply.
We bought the truck used.
Old 01-03-2005, 11:27 AM
XTerra Guy
Re: Wheel lock key
In that case. Go to the dealer, get the locks taken off as you don't want to have a flat in the boonies with a locked tire you can't get off. Then decide if they're really worth it. Unless they're nice aftermarket wheels, I would guess no. The rack tool can be bought on-line. Try www.xterraparts.com or you could always go to Napa and see if they have the right size Torx tool. The manual is online at www.nissan-usa.com. and I think also at www.xterraparts.com.
Old 01-03-2005, 02:57 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Re: Wheel lock key
I believe the roof rack Torx bit is a T-25 size.
Old 01-03-2005, 05:59 PM
Theyre just the farctory 16" wheels so no big deal. If someone wants to take them im sure they'll find a way locked or not.
Thanks for all the help everyone.
