Old 01-01-2005, 08:07 PM
tds715 tds715 is offline
Send a message via AIM to tds715
ball joint control arm question 88gt
i got a broken ball joint and from what understand you cant jsut replace the ball joint you have to replace the control arm with it, but when i look on autozones website it says ball joint only .
somoene help me
its a 88 gt
94 accord in works h23 turbo full body kit and bit of shaving and new paint
88 gt 5.0 just gettin started
Old 01-01-2005, 09:45 PM
andrewespo's Avatar
andrewespo andrewespo is offline
Re: ball joint control arm question 88gt
http://store.summitracing.com/defaul...3075a&x=9&y=13
Try Summit they have most of your needs.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
Old 01-01-2005, 10:53 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
somoene help me
its a 88 gt
I know on the 87-93 GT they changed the control arms so that you have to replace the arms and not the ball joint. But there are people who have changed the ball joints on them with some customizing but it's kind of a bitch from what I remember so I didn't go that route.
When I had to change mine and didn't have the money for tubular A-arms and didn't want to spend the cake on stamped ones. I grab a set of 4-banger one's from a junkyard($40) which are exactly the same as GT but the ball joint can be replaced. Threw new balljoints and bushings in em and threw em on the car.
Those one's summit will do the same thing so if you don't want to goto a junkyard those would be the next best route. Just paying $180 for stamped one's when all you need is a $10 ball joint kills me.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 01-02-2005, 02:41 AM
matt17 matt17 is offline
i have replaced plenty of them on the 87 and up,there not bad at all,when you go to zone and get your ball joints,tell them you want to rent the ball joint press,only thing you half to watch is when you put a jack stand under the car you half to use a floor jack to support the a-arm!
Old 01-03-2005, 07:33 PM
so the 4cyc ones are the smae as the gt ones and i can switch out the ball joint then? just wanan be clear before i go to the hill billy junkyard
Old 01-03-2005, 08:06 PM
importeater5_0 importeater5_0 is offline
Send a message via AIM to importeater5_0
my ball joint snapped on the highway(scary experience) and when i got it fixed the mechanic just replaced the ball joint and not the control arm
Old 01-03-2005, 08:32 PM
why anyone would change a a-arm because og a ball joint is beyond me!if you ever have changed an a-arm on a stang you would know that the coil springs are a PIA to do without the proper spring compressor(not impossible)just a pain and lil' scary!good luck with what ever you decide!
