Go Back   Automotive Forums Car Chat > Kia > Sedona | Carnival II
Old 01-01-2005, 07:58 PM
zbevoman zbevoman is offline
keyless entry fob
I recently purchased a 2002 sedona, it did not come with a key fob.
could any 2002 owners please tell me if your fob is a two button or three button and what is the fcc id on the back ex. bontec _ _ _ ? thank you
Old 04-08-2005, 12:39 PM
93 Max SE 93 Max SE is offline
My fob is a 2 button and the number is 003.
I have one that needs programming, how are you getting yours done?
Old 04-29-2005, 10:37 PM
fastkia fastkia is offline
Send a message via Yahoo to fastkia
Re: keyless entry fob
I can help with programming if interested
jump terms 5 and 17 on the black plug in engine bay by battery attached to the rad support, turn key, on press lock/ unlock for one second, turn key off, disconnect jumper, and test
Old 05-02-2005, 03:36 PM
fastkia, thanks for replying. Could you give me a little more detail on this? When you say jump the two terminals are you referring to making a connection between the #5 & #17 fuses? Turn key on to Acc position or engaging the starter?
Old 05-02-2005, 08:21 PM
#5 and #17 on the 20 pin connector that's attatch to the radiator support by the battery (on the left side on engine compartment) turn key on engine off.
If you need me too I will scan a copy on the whole precidure with details. Also remeber that if your van didn't come with RKE it won't work, but, you can buy the ETACS for the ex with RKE and add the couple of fuses missing from your fuse box under the hood and have factory RKE. "I must add this for whatever purposes" the marks that is.
Old 05-03-2005, 07:33 AM
Re: Re: keyless entry fob
Thanks for the detail, I will take a look at it in the next couple of days. If I have any problems I will be sure to post questions.
Thanks again!
Old 05-03-2005, 09:14 PM
ok I'll try to be in here often
Old 05-14-2005, 11:48 AM
Fatskia,
I am looking on the left side and think I see a 20 pin with a label of diagnostics. Is that what you are referring to? When I open it up, there are 20 "female" connections for the OBD2 I assume since it is labeled diagnostics. NOt all of these female connections seem to have electronic connection in them. And no matter how I count, rt to left or left to rt, number 5 and number 17 do not both have an electrical connection inside that slot. Can you PM me with the scanned instructions?
Thanks again!!!!
