Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 01-01-2005, 07:39 PM
sunshine687 sunshine687 is offline
replacing truck bed
I am planning on replacing the bed of my pick up. It is an 89 toyota that still runs great, but needs major body work. I think it would be easier to replace the bed, than to try to patch all the holes. Does anyone have any idea on how much work that would involve and how heavy is the bed. Should I have an army to help me??? Thanks!
Old 01-05-2005, 04:13 PM
KimMG KimMG is offline
AF - Advisor
Re: replacing truck bed
Yes, you will need help, 4 to five people. Disconnect the fuel filler, wiring, anything else that might cause the bed to hang up. Place a heavy blanket or furniture pad between the bed and the cab. Have saw horses or stands available to place the bed on. Undo the bolts that secure the bed to the frame. You and the small army slowly lift the bed making sure nothing is hanging it up. Check with the dealer parts counter to see if any seals or rubber pads are necessary. Ask to see the blow-up diagram (go at a time when they are not to busy).
I have used a saw-sall to cut up large body parts or cars for easy disposal. Just take the scrap metal to a wrecking yard or metal recycling center (just call ahead to make sure they will accept it).
Library may have repair manuals that may have detailed instructions.
Old 03-03-2005, 07:29 PM
Tim81ta Tim81ta is offline
Send a message via ICQ to Tim81ta Send a message via AIM to Tim81ta Send a message via MSN to Tim81ta Send a message via Yahoo to Tim81ta
I have swapped beds on my 86 single cab. I know that the beds are different in design. I did this with myself and a friend, the bed was not heavy. There was also not much attached to the bed, wiring harness, fuel filler hose, lights
Old 03-06-2005, 10:45 PM
yoda4x4's Avatar
yoda4x4 yoda4x4 is offline
i agree you can knock out the job with 2 people i have done it myself also.
Old 01-03-2006, 09:22 PM
macdad626 macdad626 is offline
Were did you guys find a bed???? Im looking for one myself
Old 01-09-2006, 09:06 AM
yoda4x4's Avatar
I actually had a friend who took his bed off to build a cage in the rear so I bought his bed.
Old 01-09-2006, 09:32 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
2WD p/u's with blown 22R's are easy to find for next to nothing (in my area). Take the bed and junk the rest.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 01-12-2006, 01:09 AM
greenhorn greenhorn is offline
First my I say the fiberglass beds are beautiful and the also sell lots of other great products. That said unless your rebuilding it I'd just spend 50 bucks on sheet metal and patch her up, cause the frame probably has it's own issues on the way if the bodies that bad if you send me some pics to [email protected] I'll give you some more informed advice and send you some pics of the patch job I've done.
