Old 01-01-2005, 07:34 PM
Automobile Maniac's Avatar
Automobile Maniac Automobile Maniac is offline
Fuel filter catch can mod is no good
I was going to do this mod today. So I am looking around and see this statement from dejontool.com--
http://www.dejontool.com/dsm-cip-faq.htm
Do I need the Valve Cover Vent tube on my new intake pipe?
What does the small hose from the valve cover do?
As pressure in the valve cover builds from boost pressure leaking into the engine, this tube vents it into the intake for a "closed system". Unfortunately oil from inside the valve cover comes with the air and lines the whole intake system. It collects in the Intercooler and degrades cooling, fouls the throttle body and collects in the intake manifold also. If your engine is in good shape you can remove the hose and put a small air filter on the intake tube (like our K&N VCV filter ($17.95) which can be cleaned and reused) or order an intake pipe without this tube. If your engine puts out alot of oil, you'll need a catch can. Drivability and performance will not be effected However you will be defeating emissions (which is illegal except for offroad). Do not plug the hose or install a fuel filter as the backpressure will impair venting.
So, if thats true, then what would basically "impaired venting" do?
Now I am thinking about not even doing it.
Old 01-01-2005, 07:53 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
you need to double read that FAQ....
"Do not plug the hose or install a fuel filter as the backpressure will impair venting. "
thoes two things will make it harder for the VC to breathe
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 01-01-2005, 08:02 PM
Re: Fuel filter catch can mod is no good
I see what your saying. Guess I read it wrong. Sounded like they were saying--do not plug the hose or do not install a fuel filter. In other words I thought it meant a fuel filter would cause backpressure.
Old 01-01-2005, 08:35 PM
kjewer1 kjewer1 is offline
AF - Advisor
It will Venting the crankcase is very important, especially at high HP (cylinder pressure). In my case I have both the side port vented and the rear port (used to be the PCV) with 3/8th rubber fuel line. It still isnt enough to completely vent the crankcase. Ideally, you would actually have a vacuum in the crankcase. It does two things. One, it gets a better seal from the rings. Two, there is less air (or less dense) in the crackcase, so you get lower pumping losses (don't forget the bottoms of the pistons pump air too ). So its not a cut and dried type situation, there are vary grades of how well that is vented. From full boost pressure, to an artificial vacuum applied with a mechanical or electric pump, and everything in between. The less pressure the better is the moral of the story.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-04-2005, 01:34 PM
whitetiger777 whitetiger777 is offline
Send a message via AIM to whitetiger777
If this is the mod I think it sounds like, then I originaly put a fuel filter in the line that goes from the valve cover to the intake and had no problems. I just recintly replace the whole line with a small airfilter nad pluged the hole on the intake and am still having no problems. There are two other DSM guys that I know who have done the same thing with no problem also. One of there is even running a 20G, the other, along with my self are running Evo III Big 16Gs.
Old 01-04-2005, 08:50 PM
Thanks for your reply, that really helps and gives me the confidence to do it. I'm gonna go for it.
Old 01-05-2005, 12:51 AM
AF - Advisor
Another thing worth noting, is that if crankcase pressure gets too high it will blow out the dipstick. Even with both ports vented my dipstick can pop up when I run high boost. I use a spring or safety wire to hold it down, might be visible on some of the pics on my site. At any rate, if you dont pop the dipstick CC pressure should be fine.
Kevin Jewer
