Old 01-01-2005, 05:50 PM
hackettjj hackettjj is offline
Unhappy 1996 Turn signal problems
My hazards work fine, brakes light work, reverse light work. Why won't my turn signal work? Is there another fuse or turn signal fuse outside ther fuse box? I hard there is another fuse located for the turn signals?
Old 01-01-2005, 06:40 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1996 Turn signal problems
There is a signal module you will have to replace.
The hazard works on its own separate module.
Cheap and plug and play fix.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-02-2005, 12:00 AM
ricksza's Avatar
ricksza ricksza is offline
The turn signals and reverse lights both use the same fuse, so you know that's good. But I believe the turn signals and hazards use different flashers. You might want to check that. You could temperary swap them and see what happens. They are behind the lighter. I am unfamilar with the signal module.
Old 01-02-2005, 08:20 AM
BlazerLT's Avatar
AF -Advisor
Yes, they are different flashers.
That is what needs to be replaced.
