Old 01-01-2005, 05:42 PM
Captain Mark's Avatar
Captain Mark Captain Mark is offline
Tyrrell Yamaha 023 F1 colour question
For those of you who are familiar with the Tyrrell Yamaha 023 (made by Tamiya, 1/20), do you know the particular shade, or combination of shades, of blue on the bodywork?
I'm talking about the main section of blue, not the lighter highlights on the mirrors and around the cockpit.
In case you need a quick memory refresh, I'm talking about the middle kit in the pic below.
Also, has anyone used the Museum Collection decals and seatbelt detail set on this particular kit? I just put my order in for one.
Unfortunately the decals provided in the kit have some brownish discolouration to them, so I'll really need some new ones. Problem is that the aftermarket kits don't have the large blue section... which means it's masking time once again.
Cheers,
M
Old 01-01-2005, 06:06 PM
Veyron's Avatar
Veyron Veyron is offline
Re: Tyrrell Yamaha 023 F1 colour question
I used Krylon True Blue but if you want to use Tamiya a 50/50 mix of TS15 Blue and TS44 Brilliant Blue would be good enough.
Old 01-01-2005, 06:11 PM
Veryon, aren't the TS colours in presealed pressure packs? Is it possible to mix them...?
Also, are you able to shoot a few pics my way of your finished kit, just for reference?
([email protected])
I'll take anything and everything you've got really, but in the end even just one reasonable closeup of the body colours would great.
Old 01-01-2005, 06:41 PM
Veyron's Avatar
Yes, they are only in spray cans but you can spray some of each into a bottle and airbrush it on. If you can't just use TS15 Blue and it'll be fine.
Old 01-01-2005, 06:51 PM
I see you have the "Mild Seven" decals on, which aftermarket set did you use?
Oh, and thanks for the pics, they look great! Did you make any additions to the engine bay, or just leave it straight oob?
Old 01-01-2005, 07:01 PM
Veyron's Avatar
I built that car so long ago I'm trying to remeber things about it.
Erm....the Mild Seven's were a decal sheet by a Japanese maker way back before Studio 27 was around, maybe Factory TZ or somebody like that printed them.
I built it OOB.
Something you might want to do is either put a whaite decal under the entire tamiya decal that goes around the cockpit or leave white paint under there because that decal is very thin so the blue shows thru it.
Also the blue on the mirrors is one of the Mild Seven blues so you will have to come up with a color for those.
Old 01-01-2005, 08:16 PM
Yeah I plan to leave it all white, then simply mask up the blue areas as per the decals - basically cut the masking tape using the decals as a template.
So the cockpit decals should come up nicely.
Here's hoping HLJ come up with the goods that I'm after - I'm finding it impossible to find any in-stock aftermarket decals for this kit!
Old 01-01-2005, 10:01 PM
To anyone who knows... looking at the above pics, where the end-plates connect to the front wing, there are two holes. Now I'm assuming those are put there by Tamiya simply to aid in fitting the parts.
Does anyone know if this is correct? And the two holes aren't actually there on the real car?
Old 01-01-2005, 10:36 PM
Veyron's Avatar
You could get this full sheet which includes Mild Sevens and the cockpit decal would be much better too.
http://www.mediamixhobby.com.sg/cata...oducts_id=1820
Old 01-01-2005, 10:51 PM
I've actually gone with this particular set:
http://www.hlj.com/scripts/hljpage.cgi?MCLDC-112
I did see the one you mentioned above, but for a handfull of dollars extra I can get the full decal sheet, seatbelts, and a few etched parts as well. It is backordered however, so hopefully it won't take HLJ too long to get it in.
Otherwise I'll be falling back on the decals you've linked to.
Thanks for the help by the way, much appreciated!
Old 01-01-2005, 10:56 PM
Veyron's Avatar
Museum Collection decals are nice and opaque but I have found them to be brittle.
Old 01-01-2005, 11:00 PM
I've read much the same on my research here actually. I'm willing to take the risk though. I don't build models very quickly, so I can afford financially to mess up the decals and buy a new set a month or so down the track.
Old 01-01-2005, 11:01 PM
crimsonkarter21's Avatar
crimsonkarter21 crimsonkarter21 is offline
Sorry, but I didn't read any other posts on here, But MCW lacquers has factory color duplicates:
Tyrrell F-1 - 2072 blue
http://ourworld.cs.com/mcwautofinish...t/catalog.html
R.I.P Formula One: 1950- 2003
Thanks for the signature- Martin_Brundle
Old 01-01-2005, 11:34 PM
Thanks CK21. Seems they don't mail their products outside the US, but I imagine someone here in Australia will be able to do something along similar lines.
Old 01-01-2005, 11:35 PM
damn, sorry, I didn't realize you were in OZ
