Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-01-2005, 03:28 PM
breeze12 breeze12 is offline
Send a message via AIM to breeze12 Send a message via Yahoo to breeze12
2002 LS im locked out! difficult question
HELLO
my 2002 LS has the right rear door locked.wont open from the outside or inside. the childproof lock feature is on, and I would guess the door rod plastic bushing has come off which is keeping me from opening the door from the outside. Question???? How do I get in to fix the door if I cant get the inside panel off??? ANY IDEAS? THANKS
Old 01-17-2005, 11:18 PM
fry628's Avatar
fry628 fry628 is offline
Re: 2002 LS im locked out! difficult question
I've never had that problem but I would try taking out the backseat to get to the bottom screws. Push in at the bottom and lift up on the seat to remove. If you've tried that then...good luck.
Certified Ford tech for 10 years
Old 01-18-2005, 05:19 PM
Re: Re: 2002 LS im locked out! difficult question
You are right on, thats exactly how the procedure went, except I just kinda ripped the inside panel off after getting somewhat frustrated. very little damage was done, the complete latch assembly was one piece and had everything including the cable, a little cosly ,but its done thanks
