Old 01-01-2005, 10:55 AM
gorb gorb is offline
98 contour wiring
i installed a stereo into a 98 contour,but there is no acc on ignition.ihooked the acc from stereo to harness but now the battery keeps dying.how can i do this without killin battery but keeping power to memory?
plz help
gorb
Old 01-01-2005, 02:57 PM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
Re: 98 contour wiring
what did you hook the acc to in the harness? There should be a memory wire (yellow) that hooks into the harness and has a constant power supply and that is what keeps the memory (obviously). But the acc, if hooked up right, shouldnt be drawing power with the car off. Unless you have it hooked to a constant, and you are forgetting to turn the cd player off.
