Greetings,
I recently bought a 95 Jimmy SUV from a private party (two days ago) within 12 hours the Check Engine Soon light came on. In taking it to Auto Zone the clerk checked and told me it was the code for the oxygen sensor. Which he promptly sold me for $65. Now I have no clue where the sensor goes, or if there is more than one of these animals on the Jimmy. Any help in this area??? Secondly my passenger side window will not go up or down with the drivers side control button and moves ever so slowly with the passenger side button, any ideas on the window problem?? Thanks in advance Gene Last edited by meyer712; 01-01-2005 at 12:10 PM. |
Re: 95 Jimmy SLT 4x4 O2 sensor code/Passenger side window problem
You need to go and find out WHICH O2 sensor it was and what the exact code was.
We need this to help you.
1995 Factory Blazer Service Manual for sale, PM if interested. |
OK, First thing Monday, Thanks for checking this out!!
Error Codes
I had Auto Zone check the codes again. The clerk gave me the following
P0141 and a new one 1406. Any ideas where these are?? Thanks in advance, Gene |
P0141
Bank 1 Sensor 2 Heater Circuit Malfunction Fix: REplace the O2 sensor that is just before the CAT convertor. P01406 EGR Pintle Location Wrong FIX: Remove EGR valve and clean it out and reinstall it with a new EGR gasket which is about $3. Use Throttle body cleaner to clean out the valve and remove any checks of carbon blocking the pintle open. Truck must be running like shit with these two codes.
Thanks
Thanks for the quick response. I will take care of both of those problems ASAP. And yes it runs like hell and sounds like a tractor. Thanks again.
Gene |
Don't let this go for a week, it will foul the plugs.
Do it ASAP. Also, reset your computer by pulling the negative battery cable after the repair are finished so the computer can rest and relearn the new efficient fuel ratio.
BlazerLt Assistance
Thanks to BlazerLt, my problem with the 95 Jimmy is solved. Check engine light is off and everything is running smoothly. Quite knowledgable and an asset to this board. Thanks again.
Gene |
Thank you, I'm glad you are up and running again.
Did you reset the computer?
