Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-01-2005, 08:52 AM
jimbosblack01LSE jimbosblack01LSE is offline
Popping noise when operating door
When I open and close the driver's door, there is a popping nose. It appears it is coming from some type of tensioner that is located between the door hinges. There is a lot of play (1/8" +/-) where the tensioner attaches to the body.
Do I just drive out the pin and replace the part??? It's only doing this on the driver's door which gets the most use.
Do you guys have a "FORUM FRIEND" who sells parts reasonably?
Thanks in advance ....
Old 01-01-2005, 08:03 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Popping noise when operating door
http://www.geocities.com/endre_rl/isuzufaq.htm#faq35
St. Charles Isuzu will sell them to you.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-02-2005, 09:43 AM
I'll order them Monday. Thanks for the reply.
Jim
Old 01-12-2005, 12:09 AM
RoyceFink RoyceFink is offline
Jim, Did you figure out what was causing the popping noise on your Isuzu door? My 2000 does it on both front doors. I bought the vehicle used & I thought it was supposed to do that. Let me know what you did, I would like to do away with that annoying sound. Royce
Old 01-12-2005, 08:01 AM
Royce, it was those worn out plastic bushings. Order you a few (about $3.00 each) Drive that pin straight up with a hammer. Remove the worn out bushing. Replace with the brass bushing. Add a dob of white grease and re-install the pin. Just a couple of minutes per door. Jim
