Old 12-31-2004, 10:44 PM
jconklin2000 jconklin2000 is offline
Angry 1998 Air Bag Light
I have no idea how to get my air bag light from coming on. It randomly lights up after I drive. I dont even have to go over bumps, but it comes on, and I dont know how to shut it off. Please help me.
Old 01-01-2005, 02:29 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: 1998 Air Bag Light
The light comes on when there is a problem with the system.
Old 01-01-2005, 02:30 AM
blazee's Avatar
Problem?
If it bothers you too much put some black tape over it.
Old 01-01-2005, 03:05 AM
cobra1 cobra1 is offline
Re: Re: 1998 Air Bag Light
bad advice......
@ blazee
you'll need to have that looked at.... sounds like a fault in the system, or damaged wiring. worse case senario is air bag inflation while driving.
Old 01-01-2005, 03:42 AM
blazee's Avatar
Problem?
Re: Re: Re: 1998 Air Bag Light
Originally Posted by cobra1
bad advice......
@ blazee
just a joke read the post above it
Old 01-01-2005, 09:37 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Usually the airbag light comes on when there is a break in the circuit... Check both your air bag sensors that are mounted to the bottom of your rad support and make sure they're plugged in. Check the one in the back. Check the fuse. Baring all that, take it in for scanning.
Old 01-01-2005, 09:47 AM
azee azee is offline
Had the same thing on a 97, it was the DERM unit, which is the computer for the air bag system.
Old 01-01-2005, 02:05 PM
ricksza's Avatar
ricksza ricksza is offline
There are too many componants in the SIR system to randomly check. Put on a scanner to at least find out which circuit is causing the fault. give me the code, I'll give you the diagnostics.
Old 01-05-2005, 03:11 PM
Allbert Allbert is offline
I'm assuming the scanners they use at AutoZone to retrieve ECM codes will not work for the airbag system. Is this correct? If it is, is there another cheap or free alternative to the GM dealership?
Old 01-05-2005, 03:48 PM
rlith's Avatar
It still should pull the airbag codes...
Old 04-18-2005, 09:47 AM
Know this is an old post, but did you ever resolve your air bag issue? My '98 has had the same problem since I bought it used last November, but here lately it seems like the light comes on more frequently and stays on longer than it did before. I'm curious to know what the most common failures for our trucks are that cause the air bag light to come on. Any help would be appreciated.
Old 04-19-2005, 12:04 AM
coryhawkins coryhawkins is offline
I'd like to know too. MY 98 Blazer 4x4 is doing the same thing. I can lock and unlock the power doors sometimes, and it goes away. It seems to come back at random.
Old 04-19-2005, 03:14 PM
For what it is worth, I talked to a GM tech yesterday about this issue, and he said it sounds like either the SDM (a.k.a. the airbag computer, sometimes also called a DERM) or the connections to the SDM. He said that this part is under the seat in the 98. I haven't taken my seat out to have a look at it yet, but if anyone else has, please let me know how things went. BTW, the power door lock thing seems to have an intermittent influence on my air bag light problem as well.
Old 04-19-2005, 03:43 PM
rlith's Avatar
Actually it's not under the seat (at least I've nbever seen it there in any 98+ truck I've worked on (tons))... Usually it's under the center console on the hump..
Old 04-20-2005, 09:01 AM
Thanks for the correction... glad I didn't take my seat and carpet out for no reason.
