Old 03-07-2002, 12:30 AM
jeffie7 jeffie7 is offline
Send a message via ICQ to jeffie7 Send a message via AIM to jeffie7
new pics of my engine swap
its almost done Im picking it up friday if everything goes as planed
yayaya I know the valve cover looks like chit but I can change/fix that after I get everything working right
check it out
http://www.angelfire.com/ky/jeffiesp...nda/honda.html
the new pictures are on the bottom of the page
Old 03-07-2002, 12:46 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
Nice.Looks good. How did the valve cover get like that tho? Oh and what integra tranny did you use(LS, GSR)??
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 03-07-2002, 05:27 PM
thats just how it came from what I understand JDM engines for the most part come in pretty bad shape
most all sensers have been replaced cap/rotor/ and the coil in the dis was broke Knock senser was broke the throttle body was bent up the list goes on...
I have a LS trans swap in place of the stock B16a trans so I can get some what of a good MPG in the next few months Im adding the draggen 3 turbo kit
I see that you have the kit with it can you keep the stock A/C? he did not put the AC back on he pulled the lines out but I have a black car and really want it becuase summer time sucks plus I have no sunroof
or power anything good ole civic DX
also whats your 1/4mile times do you have any before and after?
Jeff
Old 03-08-2002, 01:59 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
Dig your cool hood prop
I bet your radiator hoses are too small, you need a del sol radiator and hoses to make it fit right.
good luck
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Old 03-08-2002, 11:12 AM
clatescivicr clatescivicr is offline
Hey, its looking good. I was wondering will you be taking it to the track? I really want to see some true stock b16a eg civics 1/4 times. Thanks
Clate - I'm back
Old 03-08-2002, 02:45 PM
diegoaccord's Avatar
diegoaccord diegoaccord is offline
a boost guage??????????
My cars:
Civic coupe EJ1. B16A, EG6 cluster. Wrecked/parting.
CRX DX ED8. DOHC ZC, I/H/E.
EJ1 Civic Si . Screw Hatchbacks. Coupes just look better. Period...
Old 03-08-2002, 04:51 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Jeff
Well it looks good. It looks liek u have lots of room in the engine bay. I'm pretty sure u can fit ur A/C in there with no problem. My friend have a 98 gsr with drag gen 3 turbo kit and he kept his a/c on there.
Old 03-08-2002, 05:03 PM
Boost gauge? yeah Im turboing it in the next 2-3 months I knew with the new engine I would want a tach "DX does not come with one" and also a oil pressure gauge while I was at it since I had to cut drill and paint the whole pannel why not do it all at once? it would have been such a pain to do it then to have to redo it just to add a boost gauge a few months later
the stock Rad from 92-95 Civics are the same size as the B16a cars the GSR engines have bigger rads but not the B16a engine
the car was started up today everythings on track found a small water leak on the intake but that should be fixed now from swaping the part with a new one
as far as 1/4 mile times check out SCCM they did a B16a swap with a HB 92-95 and with just header exhuast and intake it ran 14.8 I've been aiming for high 14s and Im almost fully sure it will get it
top end should be pretty sick but the B16a lacks torque so from a rolling start I should have a very fast car
I love the stock cast exhuast man its a 4 to 1 header like exhuast man its great looking =)
anywho so far things are still on for tonight unless it still runs crapy "JDM engines come in really crapy cond...." as the pics show
and yes that works great for holding the hood up plus it looks good =) lol "well its not really holding it up its just pulled out of the way"
Jeff
Old 03-11-2002, 08:58 AM
crayzeb crayzeb is offline
where did you get your engine?
Old 03-12-2002, 12:47 AM
I went thu Ellis Racing check out last months SCCM his car is in there 2nd place for N/A races
almost anyplace you get a JDM engine from your going to have a engine thats been sitting around for awhile been on a boat knocked
over bent up you name it you shoujld see my old Throttle body.... eak
as with everything else
but everythings been replaced and running great now I just need to get my new 62mm throttle body working right... damn throttle sticks
Jeff
