Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-31-2004, 07:28 PM
Spinman's Avatar
Spinman Spinman is offline
Front Urethane Bushings......
My mechanic tells me that my front end bushings are starting to wear and should be replaced this spring when I have new tires mounted. He showed me a rubber donut looking bushing on the control arms - which I assume are part of the sway bar assembly - not the control arm bushing itself.
Others have posted about the pro's and con's of various materials and brands of bushings in the forum.
What exactly should I be shopping for - is there a name for the component? Is it available in a kit or individually? Are there multiple bushings that I should replace at the same time? Source?
I need to purchase and supply the parts and then my mechanic will do the work....
Thanks for the input.
