Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 12-31-2004, 04:20 PM
96HondaCivic 96HondaCivic is offline
Unhappy Car became a gas hog
I have lost almost 100 miles of driving recently. I have not added anything new to my car. Everything i have is on the bottom of this post. What can be the problem??? ANd also, when i press on the gas, my fuel gauge flunkuates, it will go down a little bit and when i press the brake, it goes back up. Is that normal?? I dont think it is. Please help. I am loosing gas!
*- '96 Honda Civic Lx 4 Dr Auto -*
*- CAI 2.5in w/aem bypass -*
*- Invidia High Performance Cat-Back Exhaust -*
*- Suno Hyper Ground System -*
*- Front Upper & Rear Upper Strut Bars -*
*- Dc Sports Rear Lower Strut Bar -*
*- Tom's Lowering Springs 1.5in -*
*- 16X7 Konig Blatants w/ 215/45 Falken Azenis -*
*- Power Stop Slotted rotors -*
*- G-Force 5 Points Harnesses(Only using 4 points) For autocross -*
Old 01-03-2005, 08:59 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Car became a gas hog
if you are losing 100 miles per full tank on an obd2 vehicle, you must have a code at least.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-04-2005, 09:15 AM
What you mean by code?? Like a fault code show on a scanner?
Old 01-04-2005, 09:31 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
I would check the filter and spark plugs to start with. After that, i would check the code. The gas guage will fluxuate like that normally...at least it does in my car. I have a 97 EX and get about 23-25 mpg in the city...what does yours get??
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 01-04-2005, 10:53 AM
ridestreet84's Avatar
ridestreet84 ridestreet84 is offline
Send a message via MSN to ridestreet84
where do you live if you live in a winter area that could be the problem, i have a cai and my mpg is horrible in the winter and thats it
Goodbye civic Hello turbo outback goodbye outback Hello WRX
Old 01-04-2005, 11:17 AM
I am in florida right now. Destin area. It was really cold but its starting to warm up. I will wait and see if anything changes. I was getting around 350 miles to a tank.
Old 01-04-2005, 01:58 PM
AF - Advisor
if bad gas mileage is your problem, go with the scheduled maintenence first. follow the guidelines in your vehicle book.
Old 01-04-2005, 06:49 PM
sohcfreak97's Avatar
sohcfreak97 sohcfreak97 is offline
Banned
dont wory about gas milelage....i gota 97 ex, i get 200miles to a tank, but thats dat comp cam at work i guess....modifying your car makes ur mpg go down
Old 01-04-2005, 08:53 PM
AF - Advisor
Re: Re: Car became a gas hog
not really. i never noticed any drastic changes in my gas mileage with an SC, turbo, or any other major mods. bad gas mileage is due to maintenence problems or bad fuel management systems. if you are getting 200 miles to the full tank, you are saying you are at about 18 miles per gallon, which suggest you have some problems with your fuel system. basic maintenence should be the first step if you do not feel any performance effects of your decreased gas mileage (tire pressure, fuel filter, air filter element, ignition timing, etc).
Old 01-04-2005, 09:32 PM
Banned
Forced Induction Is An Exception To Fuel Consumption, And To Emissions, If Ur Burning Alot Of Fuel, Ur Tanks Gonna Go Empty Fast, My A/f Is Rich Constantly Anytime I Touch The Gas, And Leans Out When Im Off, Thats Because Of The Ecu, U Can't Get Power With Out Using Gas, If Ur Car Was Stock, Then U Would Have A Problem
Old 01-04-2005, 09:46 PM
exman98 exman98 is offline
i would have though forced induction would lower your mpg especially a SC. but you due need to run higer octane with F/I.
definatly keep your fluids maintained and your tire at proper psi.
Old 01-04-2005, 09:59 PM
Banned
Super Chargers Put Out Better Emissions Than A Turbo, But Forced Inductions Burns "all The Gas" It Uses
Old 01-04-2005, 10:21 PM
AF - Advisor
looking at your post above, i belive you are trying to compare a stock vehicle vs a force induction system that uses a fuel management system of some kind. please elaborate on what your trying to say, im just very interested.
If you are using a narrowband AF gauge, then, your better off closing your eyes and guessing whether your running rich or lean. It does however do a good job at telling you when your o2 sensor is out
How is force induction an exeption? i believe what your trying to say, is, with force induction, you need more fuel to compensate for the air mixture. you do this with larger injectors or controlling the fuel pressure. If you dont properly control your injectors or fuel pressures, they will not operate correctly, which will lead you into rich or lean mixtures. Even using 440 and 550 injectors at 85% duty cycles, i never had much difference in gas mileage. its all in the tuning. Moving into the higher injector levels will significantly change your gas mileage though.
Old 01-04-2005, 10:32 PM
Banned
If Hc's Are Through The Roof, Then Ur Cars Not Burning All The Gas, Forced Induction Requires More Gas, Which Means The Gas In Your Tank Is Being Used Faster Than Pre Fi. Wideband Is A Must, Autometers A/f Gauge Is Just A Bunch Of Led's And Resitors , If He Modified His Stock Civic With Aftermarket Parts, His Mpg Will Go Down
Old 01-05-2005, 07:43 AM
I dont have many aftermarket parts. Looks at the bottom of tis post, tell you everything.
