Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 12-31-2004, 03:27 PM
kd2pm kd2pm is offline
Infinity Amplifier location
On the 98 ES, where do they hide the amp for the stereo? I believe the amp is finally heading south and I made need to replace it.
Old 12-31-2004, 05:07 PM
A. Souphound A. Souphound is offline
Re: Infinity Amplifier location
In the trunk. L/H side between the inner fender and the L/H tail light. You will have to pull the carpet away to see it.
Alvin
Old 01-02-2005, 08:04 PM
Believe it or not, I actually found the amp behind the passenger kick panel just next to the glove box. Had to pull the glove box out to get to the amp. Seems only the drivers door speakers (tweeter and mid) are acting up. May have to check the wiring some more.
Old 01-02-2005, 11:14 PM
AWP9521 AWP9521 is offline
Must be different on the 98 and up LH Cars, I had a 95 Concorde (Same as Intrepid in size) and now have a 94 LHS, both have Infinity Amps in the trunk in the same spot that A. Souphound described. It was a large rectangular and thin black colored unit that had "Chrysler Infinity Spacial Imaging Amplifier" on the label. I know the speaker layout is different from 98 and up, they had the tweeters mounted on the door frame behind the mirror mounts where the 93-97's had 3 of them on the dash, one on each end and a smaller one in the center.
Definitely check the wiring, I have never heard of very many problems with the Infinity Amps being bad other than people installing aftermarket head units in the dash and not connecting the power antenna lead thus causing the amp to not turn on, but not saying that it can happen. I had problems with the driver's side woofer in the door sounding like it was toast or not working altogether and replaced it only to have the same problem crop up again later and it turned out to be the connection right at the speaker itself was slightly corroded.
Old 01-03-2005, 08:36 AM
Re: Re: Infinity Amplifier location
You also hit the nail on the head with the infamous "blue" wire. Most cases thats for the power antenna. In the Intrepid thats the amp power lead. I found that out after I installed a new Panasonic unit and saw the graphic EQ showing output but heard nothing. So I wired it up and then got sound. THEN...I tried the CD and once again no audio. Seems the Panasonic turns off the 12V blue lead when its NOT on radio. So I eventually had to wire the ACC and AMP leads together so that when I turn on the car the amp comes on too, (even though I may not have the radio on). Best I could do with what I had.
Next stop is to get a known good speaker, tie it into the connectors at the door and work my way back towards the amp.
