Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-31-2004, 02:58 PM
Jay97Rodeo Jay97Rodeo is offline
Question what does code P1406 for Rodeo 97 mean ?
My check engine came on and when I took it to Advance Auto for a read, It showed P1406 "Manufacturer Controlled Auxiliary Emissions Controls". What does this mean ? I didn't get any meaningfull hits on google for this code. It seems the general advise is to ignore it.
I have to go for emission test in couple of week. will this code cause issues for the test since in NC, the test is done by reading the on-board computer.
many thanks
Jay
Old 12-31-2004, 04:50 PM
anthonyn anthonyn is offline
Re: what does code P1406 for Rodeo 97 mean ?
many thanks
Jay
P1406 = Isuzu EGR Valve Pintle Position Circuit.
You just need to remove and clean the EGR valve and tube. Then, remove neg bat cable for 20 minutes to clear code. Lots of posts on cleaning EGR valve, like this:
http://www.automotiveforums.com/vbul...d.php?t=329006
Old 01-06-2005, 02:19 PM
thanks for the response....
I talked to a isuzu mechanic on the phone and he says with this error code , the EGR valve has to be replaced and port holes cleaned. accordingl to him, cleaning the EGR valve will not help since the pintle is stuck in the valve.
I am not very mechanically literate. is the mechanic's advise valid ?
thanks
Old 01-06-2005, 03:01 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
What do you have to loose?
Clean it and clean the port holes on the intake manifold side and on the exhaust side.
Old 01-06-2005, 03:37 PM
amigo-2k amigo-2k is offline
Isuzu Guy
99% of the time it only needs to be cleaned. A can of carb cleaner cost 3-5 bucks. You Isuzu dealer will charge you 200 bucks for the part and install ......
http://www.geocities.com/endre_rl/isuzufaq.htm#faq1
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-06-2005, 05:12 PM
rodeo02 rodeo02 is offline
The 1993-1997 EGR system is completely different than the 1998+ EGR system. The 1993-1997 seems to have far less (carboning) problems. Like Ryan says, remove the valve & try to clean it up. Also check the vacuum line that goes to the dome & check the vac lines to/from the transducer that send the contol vac to the EGR valve.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 01-06-2005, 06:48 PM
thanks again for all your response...
I was going to try clean the EGR valve but I was curious about the mechanic's diagnosis.
This is the 2 EGR valve problem in 7 yrs. The dealer replaced the EGR the last time. This was before I found this forum. I want to be smart this time and not blindly listen to the dealers esp since the replacement of EGR is costing $450......
Old 01-06-2005, 06:53 PM
Isuzu Guy
Sure after 7 years, it is no surprise that it is carboned up and with a stick valve (cleaning it every 30k is the best way to go; quick and cheap). Smile after you fix this yourself and buy yourself a beer and enjoy!
-Ryan
Isuzu Moderator
Car Show Tips
