Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 12-31-2004, 01:02 PM
BoNkA10 BoNkA10 is offline
Send a message via AIM to BoNkA10
Blitz height?
I was just wondering if the height of the Blitz kit is the same or larger than stock. I assume it is, but not much. I need to know because I'm looking at getting either 17 or 18s and lowering the car just enough to get rid of that ridiculous gap but avoid as much as possible scraping the kit. This will be my daily driver, so I will come across spots where I run the risk of scraping.
Old 01-02-2005, 09:33 PM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Re: Blitz height?
better to put the kit on first, then do rims, then lower. cause you will be able to see how much you want to lower it based on the kit thats on. instead of doing it before hand and guessing.
Something new is coming...
Old 01-02-2005, 11:34 PM
Hpnotiq86's Avatar
Hpnotiq86 Hpnotiq86 is offline
Send a message via Yahoo to Hpnotiq86
Your wheel diameter will be the should be the same no matter what size rim you get, so....
Old 01-03-2005, 06:08 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Blitz height?
what hpnotiq meant to say is "your TIRE diameter will be the same"
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-04-2005, 02:26 AM
Hpnotiq86's Avatar
^Yeah^
Old 01-04-2005, 09:25 AM
Re: Blitz height?
I know about the tire diameter being the same. My question was about the kit, whether it was larger than stock or not and if so, by how much. I can do it before hand...as long as I have the right numbers.
Math is the universal language
1998 Eclipse GS
