Old 12-31-2004, 12:53 PM
chevy_chic20041 chevy_chic20041 is offline
Send a message via Yahoo to chevy_chic20041
Question about lifters
i've had a lifter tapping, and i put marvel mystery oil in hoping it would help but it hasn't, my question is with it tapping will it do any more damage or will it just get louder? and should i go ahead and replace it like soon or not worry about it at the moment?
Old 12-31-2004, 01:15 PM
Morley Morley is offline
Are you sure it is a lifter ticking and not an exhaust leak by the head? They sound a lot alike.
First thing I'd do is find which lifter it is and then see if the nut for that rocker has backed off, try adjusting it.
Old 12-31-2004, 01:24 PM
Brendon444 Brendon444 is offline
i had a lifter start ticking and lasted for about 2000 miles then ended up getting worse then wrecked my cam.
Old 12-31-2004, 05:38 PM
Re: Question about lifters
i am about positive its a lifter.....someone told me it would just get louder and not do any damage???
Old 12-31-2004, 07:17 PM
phantomz28's Avatar
phantomz28 phantomz28 is offline
Send a message via AIM to phantomz28
lifter ticking is normal except if its realy noticable. i noticed that on my caar but it turned out i had a loose sparkplug. check your plug or it might blow out. and its not that easy to fix.
Old 01-01-2005, 02:44 AM
Robs71Nova's Avatar
Robs71Nova Robs71Nova is offline
Send a message via AIM to Robs71Nova Send a message via Yahoo to Robs71Nova
Use a hose to narrow down which rocker arm it is while the cars running. When you figure that out, pull the valve cover off and try adjusting the rocker arm. Most of the time that will cure it. If that doesnt fix it, you will need to replacements. And over LONG periods of time, if a lifter is tapping very badly, it can wear a flat spot in your cam, then that will have to be replaced as well, but thats the worst case scenario.
Rob
Old 01-01-2005, 11:26 PM
Rob
alright thanks for the info
Old 01-02-2005, 03:34 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
yeah, i agree with Rob, adjust your rocker arms, to try and correct the situation. the ticking sound you hear is metal on metal contact, so the louder it gets, the harder the metal is hitting, so yes, the louder it gets, the worse it is for your engine.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
