Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 12-31-2004, 12:45 PM
mkingan mkingan is offline
programming instructions for 2003 mailibu
i looked around and couldn't find the programming instructions for a 2003 malibu for the keyless entry. does anyone have them? thanks
Old 12-31-2004, 01:22 PM
e2helper e2helper is offline
Re: programming instructions for 2003 mailibu
I believe it can only be done with a scan tool for that model year but I am sure someone will correct me if I am wrong.
Old 12-31-2004, 06:31 PM
someone game me this proceedure, can anyone verify if this works?
1) Sit in the driver's seat
2) Remove the ignition key from the ignition lock cylinder
3) Close all the doors
4) Press and hold unlock on the door lock switch (on the door)
5) While holding the door lock switch in the unlock position, insert and remove the
ignition key twice. DO NOT ROTATE THE KEY.. JUST SLIDE IT IN AND BACK
OUT.
6) Insert the ignition key the third time, leaving the key in the ignition cylinder. DO
NO TURN KEY
7) Release the door lock switch. You will hear 3 chimes indicating the transmitter
programming is active.
8) Press and hold the lock and unlock buttons on the keyless entry remote at the
same time (one remote) for 12 seconds. You will hear two chimes. This indicates the
transmitter has been programmed.
9) Repeat step 8 for all additional transmitters to be programmed
10) Exit programming by removing the key from the ignition cylinder
Old 03-12-2005, 05:35 PM
molehole's Avatar
molehole molehole is offline
Send a message via AIM to molehole
Just tried this listing above and it works perfectly!!!
It programmed just like it said it would and saved a lot of money- my Aunt was very happy to say the least. It should work on all Malibus but I'm not sure about other cars. Good luck and happy programming
Old 04-04-2005, 07:37 PM
rbowers28 rbowers28 is offline
This did not work on my 2003 Malibu. Thanks anyway.
Old 07-19-2005, 11:29 PM
struggle struggle is offline
This proceedure worked on a 2000 Malibu.
Thanks for the info
Old 07-25-2005, 02:33 PM
ladydevl ladydevl is offline
Unhappy
This did not work on my 2003 Malibu either. Does anyone know if there is a way without having to take to a dealer. I just purchased my car about a month ago and the dealer did not have the keyless remote. This past Friday the remote fell out from under the dash (heck if I know where from) but it doesn't work. I replaced the battery. Still no go. Tried the instructions from post #3 and that didn't work. Remote info is:
GM/LEAR 25695954 FCC ID:KOBLEAR1XT
Any help appreciated!!!!!!!
Old 10-30-2007, 10:46 AM
add3108 add3108 is offline
chevy malibu 05
do anyone know how to programm a keyless remote for chevy malibu LS 05?
