Old 12-31-2004, 11:09 AM
StealthModifier StealthModifier is offline
Head Unit Removal
how do u remove the head unit on a stealth??
Old 12-31-2004, 05:52 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i assume you're talking about the tape deck/cd receiver head unit. removal is simple. remove the square plastic piece that surrounds the head unit by using a flat head screwdriver to pry it out gently. underneath are 4 screws (on in each corner). remove the screws, then you should be able to pull the head unit out. good luck.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-31-2004, 09:04 PM
Re: Head Unit Removal
alright, thanx, i was thinkin u had to pull the whole center console out.
Old 12-31-2004, 10:47 PM
Gateway's Avatar
Gateway Gateway is offline
when I bought my pioneer head unit I removed the whole center console before I figured out all I needed to do was pull the plastic piece off and remove 4 screws.
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 12-31-2004, 11:15 PM
yea, i had to remove mine to install sirius up to it, but i finished it like 30 mins ago.. i felt stupid that i asked and it didnt even take me a minute, lol
Old 01-02-2005, 09:49 PM
The1NamedMarc's Avatar
The1NamedMarc The1NamedMarc is offline
Send a message via AIM to The1NamedMarc
Man, the brackets on the head unit were impossible to remove. I stripped 5 screws, haha. I just took a drill to them and then popped 'em off.
Old 01-02-2005, 11:36 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
i did the same thing Gateway...I was pissed after lol.
Old 01-02-2005, 11:46 PM
danseven7 danseven7 is offline
Glad Im not the only one that pulled off the console and then realized what I had to do.
Old 01-03-2005, 10:52 PM
any1 know how the heck u take the vents out??
Old 01-04-2005, 02:10 PM
Kev3000GT Kev3000GT is offline
Go to stealth316.com, then garage, then find both instrument panel removal as well as Defroster Garnish repair. It's everything you're gonna need to know. I tried to link it but just had problems.
I was just going to start a topic bout this on 3si. I'm curious how many people have actually tackled this job themselves and what kind of problems they ran in to. I've had brand new defroster vents for over a year but have never wanted to mess with such a big job!
Old 01-04-2005, 03:35 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
stealth if you talking about the middle vents that face forward. shine a flashlight in the vents and you will 2 a small tab on the bottom in the center of each vent. pull those up with screw drivers and the whole ting slides out. Then just unplug the hazard button and your set.
if your talking about the defroster vents you have to pull the dash board
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 01-06-2005, 09:30 PM
thanx guys, an yea i was meaning the double vent in the middle and the 1 on both sides.. i need to change my defroster vents too, they were cracked pretty bad when i first got the car.. each piece is into 3 pieces ,lol i called the dodge dealer an asked for defrost vents for a stealth and they said they only have it in a 1 piece... and mine is 2... i wonder why that is..
heres another thing i would like to know how to get out... how do u get the manual climate control gauges out? i found some ones that are white and glow blue at night.
Old 01-07-2005, 12:03 AM
pr0ject01's Avatar
pr0ject01 pr0ject01 is offline
Send a message via AIM to pr0ject01
yeah for the center air vents i just took a flat head gently on the side of it and pulled it out slowly. Although for the side vents I had to take apart the dash (did that also for when i installed my street glo pedals for the wiring.. hooked them up to the dimmers) although thats only the right side. I didnt get to the left side yet due to shitty weather, although im not really sure how to do it either.
1991 Dodge Stealth R/t
Old 01-07-2005, 07:48 PM
aking3000gt aking3000gt is offline
Send a message via AIM to aking3000gt Send a message via Yahoo to aking3000gt
yah i kinda just figured it out pretty simple....
1994 3000GT VR4 Pearl Yellow
1994 3000GT Base Pearl White
Check out my Cardomain Website!!!http://www.cardomain.com/memberpage/800196
