Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 12-31-2004, 11:01 AM
brogan brogan is offline
tach is not reading correctly please help!?!?
i got a 1995 dodge neon single cam and i dont know where to hook my tach to. it is a brand new autometer 5'' tach. I tried to hook it to the distributer but one of the wires did nothin and the other 2 were making the tach say it was redlineing at 4000, which is not correct because it runs fine. where should i hook it in to at? please help me...
Old 09-20-2006, 02:22 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: tach is not reading correctly please help!?!?
You should hook it to the gray wire with a blue tracer behind your instrument cluster. Tap into that wire.
* Mod Statement* I know this post may be old, but I am trying to answer the questions with no replies, to get some useful info out there.
2003 Dodge SRT-4
Old 10-04-2006, 06:38 PM
Kobaltic Kobaltic is offline
Early 95 neons (actual year the car was made would be 94) Did not have the ability to add the tach directly to the factory wiring harness. You have to buy an aftermarket kit to hook up the tach. My guess is you could do it yourself if you knew how. I never looked into it.
Old 10-04-2006, 08:42 PM
I have yet to see anything to prove that "theory" correct. I have seen a number of early built 95's that would work with a tach cluster and others that wouldn't. I don't know the difference however.
2003 Dodge SRT-4
Old 10-05-2006, 02:27 PM
Interesting. I read this on the net and went to the junkyard and tried it on 4 cars from 1994 and none of them worked with tach. I tried it on 5 cars from other years and had no problem so i assumed it was true.
