View Poll Results: How to install an HKS DUAL INTAKE FILTER ON 1993 VR4
I bought an HKS INTAKE BUT IT DIDNT WORK WHO CAN I MAKE IT WORK 0 0%
DO I NEED TO BYPASS THE AIR FLOW SENSOR OR HOW CAN I INSTALL A GOOD INTAKE ON MY 1993 VR4 0 0%
Voters: 0. You may not vote on this poll
Old 12-31-2004, 01:55 AM
3000gt1993 3000gt1993 is offline
Angry problems adding an intake
Hello I just bought a 1993 3000gt vr4 and I tried to put an intake the HKS dual filter but it didnt work because I need to plug in the air flow sensor. I also bout a filter with an adapter and it looks like my turbos over boost. It seems like its getting a lot of air but the engine dies what kind of high performance intake should I get and how can I make it work. thank you
Old 12-31-2004, 01:59 AM
Igovert500's Avatar
blue + red light magnet
Re: problems adding an intake
Ok, I'm not entirely sure what you are asking, but I'm assuming you mean that you just bought an HKS intake, installed it, and your car dies when you turn it on?
You need to plug in the sensor at the MAS. When it isn't plugged in and you turn your car on, it will run bad and stall a minute later.
As far as overboosting, I'm not sure what you mean...intakes can allow you to boost a slight bit more, but with the stock boost gauge it would still show the same readings, as it tops out at '14psi'. What specifically is the problem you are having?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-31-2004, 02:02 AM
how do I make it work where can I get a good intake that will give me performance
Old 12-31-2004, 02:05 AM
Re: Re: problems adding an intake
Old 12-31-2004, 02:08 AM
the HKS intake doesnt show you where to plug in your airflow sensor where do you plug it in ?????
Old 12-31-2004, 02:09 AM
it comes with dual filters one for each turbo but the connector for the airflow sensor is extra
please help me I want to put an intake on my car
Old 12-31-2004, 02:23 AM
Igovert500's Avatar
Um...does this look like your intake? Circled in purple is where the sensor should be plugged into the side of the MAS.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-31-2004, 02:30 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
hey igovert500, how is the air flow right there??? its been a while since i have seen a VR4 up close, but is there a little hood scoop scoop right there? as it looks, it doesnt seem like it would get good cool fresh air, but then again i dont see where else it could go?? do they make after market hoods to get better air flow to your intake?
ZedEx Crew Member #4
Old 12-31-2004, 02:36 AM
Igovert500's Avatar
Well taht isn't my vr4, but my K&N is in the exact same place as his...and as most intakes on vr4s. The stock hood has nothing as far as hood scoops in that area, but some carbon fiber hoods do...that is actually why Musashi was selling his(water was leaking in). Just remember...a vr4 has 2 turbos...so a CAI would be rather pointless, the advantage lies in opening up the restrictive stock airbox...which any open-element air filter does.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-02-2005, 02:57 PM
No it doesnt look like my intake the filters go straight to the turbos without pluging the airflow sensor. I also tried to put them like in this picture but I didnt feel any more power. it sucks more air but the engine looses power its weak.
Old 01-02-2005, 05:36 PM
Z Cars Fanatic
yes i know, it just seems like it would be sucking in rather hot air mixing with your good intercooled air. whatever works i guess...
Old 01-03-2005, 01:52 PM
mike93vr4's Avatar
mike93vr4 mike93vr4 is offline
um dont you need a blow thro set up to run aan in take right to your turbo. you would have to put the mass up by the tb right?
Old 01-03-2005, 03:31 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
you mean 2 of these
one for each housing?
