Old 12-31-2004, 12:42 AM
ZerO281eCHo's Avatar
ZerO281eCHo ZerO281eCHo is offline
Send a message via AIM to ZerO281eCHo
Timing belt/chain
can u some how change ur timng belt, to a chain, cause i dont want my belt to loose anyof the belts teeth or nething like, cause i saw this one dudes engine, and it was all fucked, cause he lost some 16 teeth of his belt, but i was just wondering if u can have that done
Old 12-31-2004, 01:17 AM
coolguycooz coolguycooz is offline
a chain as in a metal chain? first of all i think that would slip. 2nd of all the belt moves and stretches and does all kind of stuff when the engine is running and shaking and stuff.
96 RS 5 spd.(Daily Driver and ex Ricer "I am ashamed of it")
98 GSX 5 spd. (Currently stock, spending all my mod money on body work.)
Old 12-31-2004, 08:32 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Timing belt/chain
First, please just spell out you, your, and anything. Saving 1 or 2 keystrokes isn't worth raising my blood pressure.
The belt should be changed every 60k miles. Its a pretty big project. If you take shortcuts in your spelling, I would expect you to take shortcuts in your timing belt job. Have it done either by another DSMer with experience doing it, or a dealer. Avoid the regular mechanics at all costs, they just dont understand how important it is to get the tension right on these cars, or how to get it right. To get some idea of what is involved however, see the writeup at www.vfaq.com. Hope that helps, good luck.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-31-2004, 10:23 AM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Something new is coming...
Old 01-03-2005, 11:31 PM
tanx
Old 01-03-2005, 11:34 PM
so can u have it changed?
coolguycooz, what do u mean it will slip?
Old 01-04-2005, 12:47 AM
dude your talking about replacing your timing belt with a chain? a chain? as in a metal chain. lol WTF? dude the timing belt is important it runs the pulleys and stuff and its suppose to be tensioned. how are you going to get the chain to work? it wouldnt slip and stuff its a metal chain. i dont even know but im sure it wont work.
Old 01-04-2005, 08:17 AM
GSTRacerNVUS GSTRacerNVUS is offline
Re: Re: Timing belt/chain
First off GSXracer was nice enough to warn you about your typing.
Then you said
Originally Posted by ZerO281eCHo
tanx
Now, to me, this seemed pretty insulting. I would suggest that you take heed to warning.
OK down to business.
Ok... I think he's asking if it would be possible to modify his timing pully so that it would use a chain instead of a belt.
If that's not what he meant, at least it makes more sense.
A chain will last a lot longer than a belt... If you didn't already figure that.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 01-04-2005, 03:28 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
nobody has done it, or wants to... so if you feel like being a pioneer strap a chain to it and watch it fail. why are you afraid of a timing belt breaking? just service it when you are supposed to.
Old 01-04-2005, 11:42 PM
AF - Advisor
I just finally figured out what this guy was asking in the original post. LMAO. The belt won't break if it is set up properly and changed every 60k miles. So refer back to my initial post. Have it dont properly.
Kevin Jewer
