Old 12-30-2004, 11:18 PM
Feint Motion's Avatar
Feint Motion Feint Motion is offline
Thumbs down CD Burner Problems
I have an HP Desktop, had it since 2002. Since then I havent been able to burn/play anything im my CD drive. I've done system recovery, and still no luck. My DVD drive works perfect, and I now have to use that drive play all my cd's,etc. When I insert a CD(blank, Cd-rom), it make a noise, (spins fast) & it dosent read anything. Dose anyone know a soulution? I've tried CD cleaners, never read the cd.
~Josh~
OldUser:IImportSupra
Do You Have a Car that Goez Sideways?
Old 12-30-2004, 11:21 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: CD Burner Problems
HP CD/rw drives in general are JUNK. Buy a new one and that'll fix your problem.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 12-31-2004, 02:47 AM
my3rdskyline's Avatar
my3rdskyline my3rdskyline is offline
Send a message via AIM to my3rdskyline
or have one of your computer savy friends come over and mess with your computer. it's usually to difficult to explain the little troubleshooting steps I take....
Old 12-31-2004, 11:06 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: Re: CD Burner Problems
Right you are. 90% of the computers I worked on at the repair shop were HP's or Compaq's.
Feint Motion:
Make sure the IDE cable is connected properly to the CD writer and other devices, make sure the jumpers on both optical drives are set correctly, and try again. If you still have issues with the writer reading any discs, it's a dead drive and will need to be replaced.
Either something's out of alignment, the servos are shot, or the laser isn't functioning correctly. Any of the above spells a new CD writer.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 01-13-2005, 08:33 PM
Re: Re: Re: CD Burner Problems
Feint Motion:
Thanks! I Figure it was the lense, since I burned some old cd's for a friend back in 2002(they were dirty, didnt wipe them off).
~Josh~
Old 01-14-2005, 11:03 PM
Might want to have a shot at a CD lens cleaner and see what that does for you. If it's still problematic, you'd probably be better off replacing the writer. The lens could be scratched or something.
