| Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here. |
when vehicle starts it idles really rough, it runs rich also, i can smell exhaust. it was surging but i put a new iac in it and it solved that problem. also when the car is running i can hear air being sucked in, i checked vacuum lines they seemed to be ok. thanks please help
93 mustang 5.0 |
Re: runs rich,rough
Does it clear up when it warms up? any mods? Need some more info...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons..... http://www.cardomain.com/id/mccobra94 1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster. Freedom Isn't Free. |
Re: runs rich,rough
no, it does not clear when warm
it does have an h-pipe and flowmasters. i was thinking maybe replacing the maf sensor and the coolant temp sensor. please help! thanks |
Re: runs rich,rough
I Was Told The Air Being Sucked In Was The Upper Intake Leaking, So I Changed The Gasket;that Didn't Help! I Can Hear Air Being Sucked In Through The Emission Hose From The Port In Front Of The Intake Underneath Kinda, The Hose Goes To A Emissions Canister
On The Pass Side Of The Car, It Also Has Electrical Valve In It Too. Please Help Me!!!! Thanks |
Re: runs rich,rough
the valve is called a "purge soinoid valve"
Re: runs rich,rough
thanks for the response on the purge solenoid valve
would that valve have anything to do with the air being sucked in? please help thanks |
Re: runs rich,rough
could be,i try a used one from a yard or plug off the vacum line to see if things change
Re: runs rich,rough
That Sound Sounds Like What The Air Pump Is Doing It Just Pumps Fresh Air In To Keep Ememissions Down Have You Checked Your Wires And Plugs??
All cars run rich when cold as they are in open-loop mode (computer is not controlling the engine) but typically you can't smelll it in the exhaust. Have you ever pulled your codes? Go to fordfuelinjection.com and you can learn how and no tools are required beyond a peice of jumper wire and pencil & paper.
If its running rich when warm also then you may have dirty, clogged injectors (runs a few cans of seafoam thru it) or a few may be stuck open (the codes will help determine this) but if you have more than 100k miles on it then you might just want to replace them altogether. They are not bad priced on ebay (get new not used) On the 93 5.0 you have the pcv valve on the valve cover dumping onto the #8 cylinder I beleive. You need to route that vacum line from the pcv to the vacuum booster line, using a half inch tee (not sure of size) and some new hose, and plug the line going to #8. This will smooth out your idle some. Cheers, Popa Tim and his 5.0 F150 |
Ok, thats not true, open loop is when the computer evaluates the information comeing from the sensors to adjust how the car runs, hence open loop, its open to the information recieved. Your thinking of closed loop, in which case the computer has preset tables and fuel maps that the car will run on. but typically you can't smelll it in the exhaust. The exaust is probabaly the first place you would smell it because that is where the EXAUST gas goes through. If its running rich when warm also then you may have dirty, clogged injectors (runs a few cans of seafoam thru it) If his injectors were clogged or dirty it would cause less fuel to get into the car, not more. or a few may be stuck open (the codes will help determine this) An injector can't be stuck open, its fired through an electronic puls and if one was stuck on his car would be on fire due to fuel in the intake. Ok, now that I'm done with that, there are a couple things that pop into my mind. The MAF is going, it could be shot and make the car automatically run rich, or just going and sending a faulty signal. You should check the voltage your sending like how you would to set your TPS, I'm sure what the volt range should be but I'm sure someone here does. If that doesn't work, I would say you definealty have a bad gasket, throttle body maybe? you already replaced the intake gasket so thats very unlikely. You can test for leaks by putting water over places where the gasket are to see if it bubble or anything, if that doesn't work I say check the vacuum lines the same way. Hope this helped somewhat, let us know how things turn out. |
