Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 12-30-2004, 09:41 PM
madfinn madfinn is offline
oil pan drain plug
my son has a 94 ranger xlt 4x4 with the 4.0. the oil pan drain plug head was chewed up, so I picked up a new one today from the local ford dealer. Afterwards I noticed it came with a plastic washer, but when we've changed his oil in the past, there is no washer of any type on the drain plug. Question is, should there be a washer, and if so, is a plastic one used (I've never ever seen a plastic washer on a drain plug).
Thanks
Old 12-31-2004, 01:46 AM
graphicassult's Avatar
graphicassult graphicassult is offline
Send a message via AIM to graphicassult Send a message via Yahoo to graphicassult
hmmm...try it without the washer. if it works then just toss it away.
"All right Ramblers, let's get ramblin."
Old 01-01-2005, 08:39 AM
danang68_69 danang68_69 is offline
dont throw the washer away ... would you put an engine together without gaskets ? .... the washer is a gasket
Old 01-02-2005, 09:10 PM
110578 110578 is offline
Send a message via AIM to 110578
Re: oil pan drain plug
All the plastic washer is for is a gasket for the drain plug. First try the plug without the gasket and if it drips the slightest oil put the washer in. You'll be suprised that it works.
