Old 12-30-2004, 07:40 PM
brucesou brucesou is offline
93 jeep cherokee has problem with stalling
I have a '93 jeep cherokee with a 4.0 engine. It will start and idle fine, and then run for about a half hour and then quits running. Sometimes it will start right up and other times it won't start at all for some time. I have replaced the fuel pump, crank sensor, mapps sensor, cam sensor, plugs & wires, coil, computer, auto shut down relay, and fuel pump relay. No codes show when put on a computer. I like the car and would really like to get it fixed. Would appreciate any help.
Old 12-30-2004, 10:22 PM
Dale Aeppli Dale Aeppli is offline
Re: 93 jeep cherokee has problem with stalling
HI, CHECK THE FUEL PUMP RESISTER ON DRIVERS SIDE FENDER UNDER HOOD. PUT A JUMPER WIRE ON IT. IT'S A WHITE CERAMIC BLOCK WITH 2 WIRES. DALE [email protected]
Old 12-31-2004, 02:00 PM
Tried the jumper wire on the fuel pump resistor, but still stalling. It bucks and jerks at times when traveling, then stalls sometimes at corners. Can feather the gas pedal and keep it running sometimes and sometimes not. Don't know which way to turn now. Help!
Old 01-05-2005, 03:40 PM
xjterry xjterry is offline
My 93 is doing the same thing, I have only replaced the plug wires and coils so far. Have you found the problem since your original post?
Old 01-05-2005, 04:20 PM
nalaikki nalaikki is offline
I have a 99 Cherokee and am having the same problem. I think it might be a wiring problem as my alarm is also acting up and the passenger side window sometimes will not go down or up.
Does anyone else have any idea what this could be? It seems a lot of Cherokees have this problem.
Old 01-05-2005, 06:47 PM
No I haven't solved the problem yet xjterry. Still trying to figure it out.
Old 01-05-2005, 07:54 PM
Re: Re: 93 jeep cherokee has problem with stalling
Hi, check the wiring for your oxygen sensor, at sensor and around manifold and by front drive shaft. could be oxygen sensor wires are shorting out. Could be something with sensor since it starts and run till it reach temperature. Could be tripping autoshut down relay. dale
[email protected]
Old 01-06-2005, 07:48 AM
bmwilson's Avatar
bmwilson bmwilson is offline
Send a message via Yahoo to bmwilson
Not that is the same issue you have, But when one of my jeeps had a stalling prolbem at lower speeds it was the power stearing pump locking up and choking it.
Old 01-11-2005, 12:30 AM
My problem seems to be fixed, I gave up and took it to a shop that specializes in Jeeps. It was getting much worse and was stalling very consistantly at every speed. The mechanic said he found two problems, the first was a faulty Crankshaft Position Sensor, he also found that the Distance (Speed) sensor located on the transfer case was faulty. This sensor sends a signal to the computer that converts the signal to miles per hour for the speedometer. The seal had failed on mine and the sensor was wet from the ATF fluid in the transfer case. The diagnostic and replacement were a little spendy but a lot cheaper than the shotgun method of sensor replacement that I was considering. I drove it about 50 miles this evening and it ran perfectly.
I hope this helps others find their problem.
XJTerry
Old 03-21-2005, 03:23 PM
inkmonki's Avatar
inkmonki inkmonki is offline
Send a message via MSN to inkmonki Send a message via Yahoo to inkmonki
did this work for anyone else
i have a 93 sport and i have the exact same isssue as brucesou! i have searched high and low to find out why this happens. what worked for you guys?
Old 03-22-2005, 06:40 PM
Re: did this work for anyone else
i haven't found out anything yet. if you get yours fixed, please let me know.
