Old 12-30-2004, 04:59 PM
project14 project14 is offline
Angry Help. Flooding
I have a 88 dodge diplomat with a 2bbl 5.2L 318 and just recently it started to act up on me. When I start it up it runs fine for about 2 min then it starts to run rough and fuel bubbles out of the carburetor and the motor floods. What would cause this and how would i fix it?
Thanks
Old 12-31-2004, 12:30 AM
foureyedbuzzard foureyedbuzzard is offline
Re: Help. Flooding
Thanks
Sounds like the float is stuck open/down or the needle valve attached to same is not seating. The gas is filling the carb bowl but the float is not rising with it and/or the valve is not seating and shutting off the gas flow. I would suspect that the gas is probably coming out of the bowl vent tube. Try giving the carb a few gentle but sharp taps with a small hammer(BUT DON'T BREAK ANYTHING!) Sometimes you'll get lucky and the offending float/valve will unstick. This is probably a temporary fix at best. You could also put some carb cleaner in your fuel, I'm skeptical as to whether or not the stuff actually works but for a couple of bucks it won't do any damage. If all else fails you'll have to disassemble the carburetor and clean and/or repair it. Many times this can be done fairly easily by removing the top of the carb and replacing the float without doing a kitchen table rebuild - depends on the type/make carb. I'm not a pro mechanic, so I don't know your exact system.
Oops, forgot to ask, does the carb have electronic float control? My wife owned a Chevy Citation POS with one and I honestly don't know if something in those systems could cause the problem you're experiencing, I wouldn't think so, but...
Read more on electronic float control at: http://www.allpar.com/fix/fixcarb.html
Old 01-02-2005, 10:48 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Help. Flooding
^^good post^^
I might suggest rebuilding the carb using a kit AND get a new float. Usually new floats are sold seperatly. You must remove the carb, but you can clean up the insides and inspect/replace all the necessary pieces. It's usually the best way to permanently fix the problem.
Old 01-02-2005, 09:16 PM
public's Avatar
public public is offline
Re: Re: Help. Flooding
Originally Posted by MagicRat
^^good post^^
Ditto. There is no substitute for a good rebuild.
Yes, I am retarded.
Old 01-03-2005, 08:28 AM
RandomTask's Avatar
RandomTask RandomTask is offline
Banned
Re: Help. Flooding
I just want to add: be careful on the rebuild, there are a LOT of tiny parts in the carb that are essential. Make sure you're working in a very clean and tidy area....
Old 01-03-2005, 09:30 PM
Not only are the parts tiny, but at least half of the suckers are round (in at least two dimensions) and roll in ALL directions of the table - I hate that!
