Old 12-30-2004, 04:47 PM
Semimech Semimech is offline
97 Buick Water Pump Replacement Hitch
Trying to replace the water pump on a 97 Buick LeSabre for a relative. After doing a search, looks like I'm better off than with an earlier model and the problems associated with the engine mounts. However one of the main bolts, (about 3 inches long), is just barely behind the pulley on the power steering pump. Any ideas of how to move the power steering pump to get access to one of the main bolts holding the water pump on? It's difficult to see the power steering pump because of its location..... down low and close to the firewall. Any help would be appreciated.
Old 12-31-2004, 02:05 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: 97 Buick Water Pump Replacement Hitch
The power steering pump has hole inside the pulley, use this to your advantage! Use a deepwell socket through the holes to access the bolts( I think 15mm, not 100% sure though) add a socket wrench, and you'll have that pump off in no time! I'd suggest buying an inspection mirror to see in small places like that, mine's very handy.
Old 12-31-2004, 11:44 PM
Re: Re: 97 Buick Water Pump Replacement Hitch
tman2093, thanks for taking the time to reply! I appreciate you help and looking forward to trying your solution.
