Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 12-30-2004, 04:20 PM
notkidding notkidding is offline
Code P301-304
It seems that I have a misfire in EVERY cylider!! Any ideas what can be causing this???
I have a 1999 Passat. When I start the car it barley starts. Then I have to let it idle (very rough) before I can start driving it. When I first start driving it It will bog down even if I have it at full throttle. It sits there for like 3 seconds or so then it takes off and runs fine until I come to a stop again. Then the same thing happens. After I have driven it for awhile it doesn't do this anymore.
I had the diagnostic done and they told me that I am misfirring in every cylider. They suggested the timing belt skipped. Any other ideas?
Old 12-30-2004, 06:20 PM
boschmann boschmann is offline
Re: Code P301-304
Which engine? In addition to ignition problems I'd also look at the mass air flow sensor. It can get out of calibration & cause all sorts of codes. You need a scanner that can view the datastream of the sensors & ECM.
Old 12-30-2004, 09:03 PM
Re: Re: Code P301-304
It is the 1.8T. I just had the diagnostic and the only codes that they pulled was the misfire in each sensor. I believe they said that it was the P301-304. Other than that they didn't pull anything else.
Old 01-01-2005, 11:05 AM
Re: Code P301-304
The 1.8 had a problem with the ignition "module" but it usually just causes a miss on #2 cylinder. I'd look for a non-ignition cause such as the MAF or a vacuum leak.
Old 01-03-2005, 01:46 PM
OK so the shop checked the timing and it was perfect. The mechanic said that he thinks it is the fuel system... Well somewhere in it. What do you guys think of this? Could the injectors be faulty?
Old 01-03-2005, 07:47 PM
Re: Code P301-304
Were there any other codes in there?
Old 01-03-2005, 09:43 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
If its a 1.8t it could possibly be the POS (power output stage) on top of the air cleaner box. It controls spark on all cylinders and usually goes bad arround 80-100K miles. Unfortunately its a $450 part. You can check it with a test light- Unplug the engine side connector then have someone try to start the car. Try each terminal with the test light while trying to start the car, each terminal should flash.
Old 01-04-2005, 09:36 AM
Re: Code P301-304
The car is in the shop right now. I'll call my mechanic and have him test for that. Would this throw it's own code or do you just have to know to check that? I have 90k on the car.
I didn't get any other codes from the mechanic. He just told me that he got some fuel systems hits on his scanner.
Old 01-04-2005, 10:50 AM
VDUBMAN
I have never seen an injector or fuel related part go bad on a vw. The fuel filter could be a problem if it is too clogged and is a cheap repair (also helps on gas mileage and power alot). The POS wont set a code for the unit itsself, you just have to find it as the culprit as per the testing i had before. Also a faulty MAF sensor or ECT could cause misfires in all cyl. if they were very bad. Also large vacuum leaks could cause misfires in all cyl.
Old 01-04-2005, 11:38 AM
Re: Code P301-304
Man... There are a lot of posibilities aren't there.... It is going to cost me like $500 to just figure out what is wrong with it.
OK so before I had my timing belt and turbo replaced I didn't have this problem. What could they have messed up while replacing those parts that could cause this? I wonder if they just didn't hook something back up right. I have already had the timing check and it was perfect. Wouldn't the MAF or ECT throw a code that could easily be tracked if they were bad?
Old 01-04-2005, 08:14 PM
Re: Code P301-304
OK so I got the car back from the mechanic. He did pull a 17708 code. What is that?? He did replace the clogged fuel filter, but that didn't fix the problem. Any ideas besides the POS?
Old 01-04-2005, 08:21 PM
Re: Code P301-304
I found that the code 17708 is a misfire because the fuel is too low. The tank is full.... Could at one time this have happened and it has fixed itself or something?
Old 01-05-2005, 11:42 PM
VDUBMAN
Fuel to low sounds like the clogged fuel filter. I have seen codes for misfires and a code for low fuel at the same time. Check the ECT (at the rear of the engine between the engine and firewall. If its not green then replace it- only $7.00 worth of parts and u problably need it neway)
When you fix a car with lots of miles things tend to break. An engine that has not had full boost pressure now is. Your MAF might be faulty now because of the boost pressure. Also they should check to see if all the vacuum lines and hoses are correctly installed on the turbo and intake pipe. There are alot... ALOT of vacuum lines and rubber hoses that need to be removed and installed when doing a turbo on a passat and I am sure they might have forgot one or two or possibly one hose may have cracked.
Old 01-06-2005, 10:13 AM
Re: Code P301-304
OK So after the fuel filter was replaced the check engine light hasn't came on. It starts a bit easier now, but still bad. I'll replace the ECT this weekend and see what happens. If the MAF bad wouldn't throw a code? Maybe it is just out of calibration. If it is is there anyway to recalibrate it? When the trubo was replaced they did replace a couple of vacuum line that were cracked. I'll try and case them all down to make sure that the hooked them back up right.
Old 01-11-2005, 12:34 AM
VDUBMAN
There is no way to (calibrate) a MAF sensor, but you can clean it with some 99% alcohol. You might also have some carboning of the valves. Try a full can of "seafoam" $8.99 at checker auto parts in a 1/2 tank of gas. That should more than blast your injectors and valves and pistons clear of any carbon or residue buildup.!
