1994 s15 jimmy not runing right
Hi,
I need some help with my 94 S15 Jimmy. I'm getting gas out of the vapor canister. Does not happens all the time, but when it does the jimmy runs really bad! NEED ALL THE HELP I CAN GET |
Re: 1994 s15 jimmy not runing right
More information bro, we can't do shit with what info you have provided us.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Gas problem
Could your fuel return line to the tank be plugged up?
Can you blow it out with compressed air (take the cap off the tank first)? Could your gas cap not be venting and not permitting gas return to the tank? Bob Shaw |
Re: Gas problem
Gas line problem
You may be right Blazer LT but I have seen the problem and done just that. It was dirt in the return line. What is your recommendation?
Don't be negative unless you have a better idea. Bob Shaw |
We can't do anything with this guy, he is far to general with his problem.
more info the gas tank was changed , and the jimmy has not run right after that.
now it will not start. station says I a new injection system. or is it more like bob said about the return lines? |
Re: Re: 1994 s15 jimmy not runing right
My guess is that the problem is AT THE TANK since that is what you changed last. Bob Shaw |
the fuel filter was changed with the tank, and the tank was fine.
so the main line and return lines may be crossed? |
Is yours the TBI or CPI fuel injection system. IF it is CPI, you could have a low fuel pressure problem. Or even a battery problem. If the battery voltage is too low, it will screw up the computer and fuel system. Bob Shaw |
it has the cpi system , and have had the gas cap off with on change.
what would happen if the cpi was leaking? |
Could very well be.
Take a flashlight and look down in the hole under you vortec top plate cover. You will have to remove the round IMTV valve to look in. Then look for washing amd golden spots and the smell of fuel.
