Old 12-30-2004, 01:17 PM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
2400w x 2 @1ohm???
I'm looking for a amp to push my 2 SPL W12s there rms is 2400wx2@ 1ohm. the only thing i can find is a audiobahn amp is it worth 360$??
If nebody knows of other amps that can do this drop a link here.
Old 12-30-2004, 02:16 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: 2400w x 2 @1ohm???
damnit, I had a whole response typed up and then it didn't post and I lost it....in summary, those subs can't handle anywhere remotely close to 2200rms, don't dare go more than 1000rms each or there's an extremely good chance you'll melt down both of them. Also, those subs are dual 1ohm, which means a 2ch 1ohm stereo stable amp won't work, you'll need a 1ohm stable mono amp.
Something like a hifonics brutus 1800d would work, but be vary careful with the gains, who knows when those things will go up in smoke. And in the future, be very wary of any sub that claims a power handling greater than 6-700rms and is less than $200, and be even more wary if the only "specs" that the manufacturer lists are retarded cosmetic shit instead of the T/S parameters.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 12-30-2004, 03:38 PM
Dreamspawn's Avatar
They had a lifetime warrenty on them pretty sure. So if i smoke them get a new set. thinking bout getting rid of them for some mtx punch.
Old 12-30-2004, 06:52 PM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
Re: Re: 2400w x 2 @1ohm???
why is that?
Old 12-30-2004, 07:07 PM
sr20de4evr's Avatar
that warranty doesn't include abuse, and overpowering is abuse
'01 Black Sentra SE
'05 Silver WRX STi
Old 12-30-2004, 07:09 PM
sr20de4evr's Avatar
Re: Re: Re: 2400w x 2 @1ohm???
Originally Posted by RickwithaTbird
why is that?
each sub has 2 1ohm coils, which means each sub can be wired to .5ohm or 2ohm. Then you can take the two subs, and wire them together into a SINGLE 1ohm load or 4ohm load (depending on how you wired it). If each sub was say 1000rms, in order to power them properly you would need an amp that did 1000x2 @ .5ohm or 2ohm, or an amp that did 2000x1 @ 1ohm or 4ohm.
'01 Black Sentra SE
'05 Silver WRX STi
Old 01-07-2005, 01:55 PM
Dreamspawn's Avatar
I know its been awhile since i ever made a reply to this but been kinda busy. I wired them like the mnual side one side get the straight postive the other gets the stright negtive the criss cross. So what amp would i need? Or u think i should just try to sell them and go with somthing else? I know i want 2 12s that will thump the shit out of the maro.
Old 01-10-2005, 11:28 AM
schemo schemo is offline
you can wire each sub in series to bring up the ohms to 2ohms, then wire the two subs together in parrallel to bring the two subs back down to 1ohm. if all you are planning to do is run those two subs i would get a mono punch amp from rockford fosgate they are iohm stable, and that will be more than enough. you never want to run your subs so high when down to 1ohm, you can burn out your voice coil in a snap!!!!
Old 01-10-2005, 11:30 AM
oh and another thing read the specs on that audiobahn amp carefully they tend to overate the power rating to fool people that don't know any better
Old 01-10-2005, 12:22 PM
sr20de4evr's Avatar
it wouldn't burn out any faster than at say 4ohm if it was the same power
'01 Black Sentra SE
'05 Silver WRX STi
Old 01-10-2005, 01:23 PM
Dreamspawn's Avatar
So i need a 1ohm mono amp. Kk let the search begin.
Old 01-10-2005, 01:24 PM
any amp working at 1ohm is working for times as harder than it would be at 4ohms. touch an amp working at 1000watts compared to an amp at 4ohms pushing the same power. which one feels hotter? 1ohm draws and comsumes alot more power than 4ohms.
and more power always equals to more heat and distortion (at higher levels).
all that would be needed is one low wave hard wave and you can easily burn out a voice coil, like you said speakers in your previous post the subs are warrantied, but not against abusive actions.
just my input from experience, by all means i am no engineer.
Old 01-10-2005, 01:27 PM
you won't find to many 1ohm amps out there that are really good, in my opinion.
Old 01-10-2005, 01:42 PM
Dreamspawn's Avatar
What would u suggest?
Old 01-10-2005, 02:27 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
what are you talking about? Dreamspawn dont listen. There are a ton of 1ohm stable amps out there. what is your budget on an amp?
p.s. dont listen to a newb that questions/argues with sr20
