83 subaru gl stopped
1983 subaru Gl 1800 5 speed manual. 260,000 miles. I've been driving it since it had 50,000. Stopped running drving down road. No gas to carb.
Checked fuel filters. Disconnected electric fuel pump and wired to battery. Started pumping. Reconnected pump, turned engine over..nothing. No hum, vibration etc. Disconnected fuel line to carb., turned engine over and gas was pumping out. Why won't fuel go into the carb? For 6 mos. I've had to start car by using starter fluid. Once it started it drove fine, but I never could start car after it sat for a while unless I used starter fluid or gas to prime this thing. Any suggestions as to what to do next. Thanks |
Re: 83 subaru gl stopped
there are solenoids within the carburetor that meter fuel to the jets. look at all the electrical relatd to the carb and test the components with a volt meter and reference material for the volts and resistances
I invented the TrashWagon. 83 GL wagon, originally yellow, ea81, 2wd 5wpd now it has an ea82 motor, a 5spd dual range 4wd transmission, ea82 front suspension and rear isc brakes sheetmetal body armor, and krylon paint job shag carpet interior, and a stereo system mounted on the ceiling "roof of Boom" [email protected] come see http://usmb.ultimatesubaru.net |
