Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 12-30-2004, 10:35 AM
MttFrdrksn MttFrdrksn is offline
1996 Infiniti I30 won't start
I have a 1996 I30 that won't start. Battery is six months old and still strong. When I turn the key it just won't turn over. It doesn't even try to turn over. Any help would greatly appreciated. I suspect that it is the wire leading to the starter came loose.
Old 12-30-2004, 12:11 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 1996 Infiniti I30 won't start
Have u cleaned Terminals?
See for the battery grounding: http://www.cardomain.com/memberpage/748507/10
Take a multimeter and inspect that you get +12V at the starter terminal (bend off rubber boot -shield)
Solenoid should give a click. If not, you are not getting any pwr from auto tranny ign inhibit relay (does it click), maybe stuck? How about the realy controlling tranny pos switch, does it activate when on P or N. If not, no start.
Or ign sw itself bad.
Chiltons crap Maintenance Manual Online:
http://www1.autozone.com/servlet/Ui...&Parameters=004
Old 12-30-2004, 04:54 PM
Thanks for the info. I went out this morning and it started right up. this has happenned once before and I think the owners manual has something in it about this maybe happening due to the security system but as I cannot find the manual I did not know the quick remedy to the situation. This morning I went out and armed the alarm with the remote and unlocked the doors with the remote and it started right up.
Once again thanks for the help.
Old 12-31-2004, 01:04 AM
Find out the fuse for it. Next time as problem exists, take taht fuse out. If that is the problem, will start, roots found.
Old 01-07-2005, 11:33 AM
infinman infinman is offline
If this happens again, manually {with key} lock and unlock drivers door.Then try starting.If this works get back to me.
