Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-30-2004, 02:02 AM
george536's Avatar
george536 george536 is offline
Exclamation Clutch stuck to the floor!!! help.
Ok today i started up the car and it was ok. Drove around, then went to work and parked it. then 5 hours later get into my car start it up and go. When all of a sudden the clutch started sticking to the floor. I had to bring it back up with my foot. Then it would be hard to shift to other gears. Really hard. Untill my clutch just got stuck to the floor. So i had to stay in second the whole time. I parked it. Then my clutch would not go up by itself i would have to pull it up. I pulled it up and started it up. then pushed the clutch in to put it in first and it wouldnt it wwas just stuck to the floor.
So i called my friend and he told me to check my clutch fluid and theres was none in there only microscopic size left. Then my friend said i got air in the clutch now and will need to get it bleeded. I put fluid in there and it still didnt come up. So now it was towed to my house parked in front my house not knowing what to do. If i take it to get the clutch bled will it fix my problem? or is it something else? How much will this cost me? PLease help!!!
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 12-30-2004, 08:17 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Clutch stuck to the floor!!! help.
I would bleed the clutch, that should take care of your problem. The real question is....where did the fluid go????
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 12-30-2004, 09:24 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Check on top of the clutch pedal. You will feel fluid there and its leaking or something like that. Talk to Vince or search for his thread on this same thing, he had the same thing happen.
For Sale 98 Eclipse GS, 5 spd
