Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 12-29-2004, 07:29 PM
DEADMEAT101 DEADMEAT101 is offline
Send a message via AIM to DEADMEAT101
HELP!!! 1995 electrical problems???
My friend just got a 1995 oldsmobile Silhouette, rung rough (needs tune up/exhaust) and has a lot of problems that i am hoping are all linked. probelms are as follows:
-Tach/speedometer dont work
-Blower front or rear dont work
-ABS light on
-Traction control light on
-Low gas light on
-power windows dont work
-at full throdle its slow
-radio works sometimes not others
-Chms when lights are on
-auto door not working and a few other problems
is the ECU bad and its in limp mode, bad ground, abs module bad? i checked the relays and fuse to no luck so anyhrlp would be great... THANKS...
Old 12-30-2004, 07:05 AM
Milo2001 Milo2001 is offline
Re: HELP!!! 1995 electrical problems???
I had the same thing happen on my 97 Grand Prix. It wound up being a dead alternator which in turn killed the battery. I would take the Alternator to a Advance Auto or the like, they can test it for free.
Old 01-15-2005, 02:37 PM
silhouette silhouette is offline
Well I think your friend has my van..lol Mine just started acting up with most of the things you mentioned.
Abs light on
low gas light on
dinging with lights on
rmp arent registering
Power windows arent working
No heat
There are probably a few more that I am forgetting, I was hoping you figured out what was wrong with your van. So I kinda know where to start.
Old 01-15-2005, 09:15 PM
yep, i found out it was the ignition switch (electrical not key) it was 12.99 at autozone and only problem is tearing steering column appart to replace it...
1995 Ford Mustang 3.8L AODE coupe...
1997 GrandPrix GTP 3.8L SC sedan...
coming soon 1998+ trans AM LS1...
