Old 12-29-2004, 08:07 PM
Saia Saia is offline
Unhappy 70 Olds "No Spark"
I Have a 70 olds Cutlass 350 engine. I did a tune up this weekend and changed the points, cap , rotor. Now i get no spark to the plugs. I tried 2 coil wires and 2 different coils and still no spark. Anyone have any idea's.. I put back on all the old parts also. The car was running great 20 minutes prior to the tuneup.
Thanks
Old 12-29-2004, 08:39 PM
4speedsupreme's Avatar
4speedsupreme 4speedsupreme is offline
Re: 70 Olds "No Spark"
Did you gap the points?
Old 12-30-2004, 03:12 AM
Yes, reset them twice once at 16 deg and again at 19 deg
Old 12-30-2004, 11:18 AM
public1 public1 is offline
have you checked the point gap, made sure your condenser and all have proper ground and so forth. all this will help. i have a '69 cutlass 350 engine on the ground if you need the distributor. make sure that all your wires are plugged in and that you didn't pull anything loose by accident.
