Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 12-29-2004, 06:36 PM
zdude zdude is offline
Send a message via Yahoo to zdude
injectors
so i talked to my grandpa about the reasons as to why my 240 might have burst into flames. he used to own a maxima and he said he had the injectors replaced. he can vouch for 10 other nissan vin numbers as well that had injector problems. my uncle took his 300zx in for injectors and there was a burnt one in the back with the same problem. do you think the faulty injectors on my 240 couldve started the fire? and also...im just letting you all know so you can check it out if you havent already done so...
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
89 240sx (sold then died)
85 735i (Died)
95 Corolla (Damn Deer)
94 Renault Espace (gave away lol)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
Old 12-29-2004, 07:05 PM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
I don't think it would be the injectors as much as it would be the O-rings around them. A serious leak in one of those could spill enough gas to start a fire. A small one. Maybe.
How big a fire are we talking?
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 12-29-2004, 07:07 PM
TatII TatII is offline
how would bad injectors cause fire?
a bad injector would cause you to run either rich because its frozen and stuck open, or lean casue its stuck closed.
or you could just have leaky injectors which means the o-rings are worn, and its not sealing up the pressure perfectly in the fuel rail and the fuel is just dribbling down constantly.
what could be a possiblity is a corroded harness or electrical connection. there resistance is too great and it caused great heat, which caused a electrical fire.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 12-30-2004, 03:08 AM
4 foot flames. it actually happened 5 days after i sold it, he lost all hydrolic pressure, pulled over with the ebrake, and 4 foot flames instantly shot out from under the hood.
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
85 735i (Died)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
Old 12-30-2004, 04:33 AM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Re: injectors
...and thats why you dont use NNAaaaWWAWSZZZ
Old 12-30-2004, 02:10 PM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
Ahhah
Hydraulic Fluid is ummm Flame-able! In shop at my Aviation Maintenance class we lit hydraulic fluid in this steel bottle with a bout a pint in there and it shot a flame out of the top the bottle like 7 inches like a blow torch... not very hot though. so a Hydraulic leak... and a flame.
Old 12-30-2004, 02:27 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: injectors
Where under the hood did the flames come from?
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 12-31-2004, 02:40 AM
Re: Re: injectors
dunno. but there was a huge hole in the windshield right above the wiper motor. so im guessing the passenger side mostly. the hydrolic lines run across to that side, so that could be it...
RAF Mildenhall, UK
92 Paseo (Died)
90 Corolla (Died)
85 735i (Died)
94 BMW 316i
97 BMW 528i
97 Blazer
[email protected]
Old 12-31-2004, 04:08 PM
Bo240sx Bo240sx is offline
Send a message via AIM to Bo240sx
Re: injectors
yea i have to get the fuel injector replaced on my car very soon cuz its leakin gas all over my engine which isnt good...
Yea...its a Chick Thing
But ya girls who drive imports, lifted trucks, and even girls who drift are the hottest!!!!
^ ^ Well said ^ ^
Old 12-31-2004, 08:08 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
Re: injectors
KIX THAT! i just fixed the lie to my fuel filter, it was leaking everywhere!
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
Old 01-01-2005, 02:33 AM
LaYzIeNoY LaYzIeNoY is offline
Send a message via AIM to LaYzIeNoY
i think it might be that hydraulic fluid
the heat of the engine would set it off rather quickly if it leaked, espcially if it touched hot metal like headers, but for it go 4 feet that would need something besides hydraulic fluid alone i think
maybe it was a combination of things
hydra fluid leaks small flame not seen, melts something gas sprays out, and boom fire
you said there is a hole in the windshield that must've been a pretty hot flame to do that
Old 01-01-2005, 12:13 PM
wingsofwar's Avatar
wingsofwar wingsofwar is offline
Send a message via ICQ to wingsofwar Send a message via AIM to wingsofwar Send a message via Yahoo to wingsofwar
Re: injectors
Nissan Injectors used during certain cars in the 80s and early 90s were faulty, and caused leaks. Check your VIN number for a recall. My Z31 300zx burst into flames because of the injectors. As well as others did if there was no recall done. There are many ways your car can burst into flames....and injector fire is usually a good portion of the situation.
