Old 12-29-2004, 06:15 PM
nymorey nymorey is offline
Send a message via AIM to nymorey
Drive axle Hub Nut size
Anyone know what size the drive axle hub nut is? I need to replace the bearing assy and would like to get the right size axle nut socket.
94 Lumina Z34
3.4 L DOHC
Old 12-29-2004, 11:30 PM
dwalmop dwalmop is offline
Re: Drive axle Hub Nut size
38mm I believe
Old 12-30-2004, 07:14 AM
Manny_boy's Avatar
Manny_boy Manny_boy is offline
36mm (did both my fronts not too long ago...)
Old 12-30-2004, 03:27 PM
Unhappy
thanks .
projects for this weekend
Timing belt replacement
Power steering return line replacement (of course it's behind the motor)
Front wheel hub assy
Replace crankshaft oil seal
All tips welcome
It never ends!
Happy New Year!
Old 12-30-2004, 04:17 PM
oops sorry I always get that mixed up
Old 12-30-2004, 05:20 PM
logankelly logankelly is offline
Put transmission in neutral then take off front motor mounts and you can rotate engine forward to allow room in back to work
Old 12-30-2004, 07:52 PM
Re: Re: Drive axle Hub Nut size
There are 3 mounts right? 1 upper, 2 at the timing chain end and one at the transaxle end. So which ones do I remove (I know about the upper one) and which ones do I loosen?
Old 01-01-2005, 12:42 PM
Manny_boy's Avatar
You have a 3.4. Don't bother removing your mounts in the fleeting hope that you engine will tip forward. It won't. Only the 3.1's were afforded that luxury.
Old 01-01-2005, 05:16 PM
I think I have finally figured that out.
Thanks
