perf shift
i got a question. i just so happen to be driving home today and my low washer fluid light was one and i notice something above it it said ( perf shift) what is that? i had my car for a year and sad to say i just noticed it, the sun was shining real bright today. and also to the shift lock thing on the side of the shifter can that come off or what?
Re: perf shift
Not sure what year or type of GP you have S.E,GT or GTP
~Larry~
![]() ClubGP Member 6530 Since 2001 |
Re: perf shift
Performance Shift
On my 98 its blue which makes it difficult to see. Also for some time it stopped working, then after someone jacked my headunit it started working again. |
Re: perf shift
I think what Big-L is saying, is out of the stock cars, the GTP and GTX are the only two with per. shift.
And Tim, both my 98s blue lights. When the sun hits the dash, can't see them at all. But look good at night.
Re: perf shift
hey,
does anyone know if the perf shift light exists on the newer GTP's that don't come with it? is it displayed on the dash or the DIC? |
Re: perf shift
No, the only thing you can get is the Comp package. Shift buttons on wheel. Doesn't raise press in trans. That's per Pontiac.
i have a 2001 gt the light never on tho so i dont
and what does it suppose to mean anyways? so if it only comes on gtp and gtx whats it doin on mine?
Re: perf shift
A reprogramed PCM will give it to you also. But you would have to wire a switch to turn it off. Or buy the shift knob from a GTP or GTX. Then wire it.
oh really thats pretty hot there, ill have to look in to that then. so i can either buy the shifter or the computer right it wouldnt make a differents?
Re: perf shift
The PCM will give you per. shift. But you will have no way of turning it off, without a switch or the button on the switch.
On your car, without the PCM you won't have per. shift.
Re: perf shift
http://zzperformance.com/zzp/product...dhp_pcm_10.htm
You are going to want to get this Smoothrider |
yea imma have to do that. thanks
Re: perf shift
After you do this, the Performance Shift light in your DIC will be lit when the system is on. |
I have a 00 GTP with the Performance Shift Feature. When you turn it will shift at really high rpms like just before it hits orange but sucks a lot of fuel. Why didnt they put it in the 01 to 03 models? Which years did they have it in?
