| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Left blinker does not work.
My left blinker doesnt work, but my right one does. what can be the problem? i changed all the bulbs but didnt fix it. Is there a fuse just for the left one?
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
Re: Left blinker does not work.
I think both are on the same fuse. Do the parking lights work on the left side?? Grab a test light, turn on the blinker and see if you are getting power to the socket. On my beater car (74 mustang) one of the sockets died for no apparent reason....I guess the bulb wasn't making good contact.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Check the wiring harness also.
For Sale 98 Eclipse GS, 5 spd |
Did you check your blinker fluid? Might need a refill or a flush!
Re: Re: Left blinker does not work.
you think your funny now dont you
My left parking lights do come on. It just doest blink.
Mine did the same, wires that plug into the hazard flasher box (I think this is what it was) were half way unplugged.
I box was behind the stereo in the center of the dash. I checked dverything first, traced the wiring down and of course I was due for an inspection. Last thing we tried was looking at the wire schematics in the Chilton and located the box. Could not see it but felt a plug loose with my hand, pushed on it, it clicked and the blinker has worked every since. |
