Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-29-2004, 04:24 PM
aznbmxxxer aznbmxxxer is offline
Send a message via AIM to aznbmxxxer
water pump leaking, need help!
i have a integra and the coolant started to leak where the water pump is. so i took it apart and got a new gasket, i bolted the water pump back on and filled it with coolant. it still leaked, so i put the high temp gasket maker over the rubber gasket and filled it back up with coolant, and it still leaks, what can i do to make it stop?
Old 12-29-2004, 04:32 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: water pump leaking, need help!
get a new water pump, the bearing is probably bad.
Old 12-29-2004, 09:34 PM
casperGSR's Avatar
casperGSR casperGSR is offline
Send a message via AIM to casperGSR
just like greenblurr93 said replace the waterpump but in addition make sure when you put the new pump and gasket on that the side of the engine is cleaned off of all the old gasket or rtv that may be on there and that it is dry before putting the new gasket on, also it isn't a bad idea to put some rtv in the groove of the new pump where the rubber gasket sits before putting the gasket on.
Built and boosted...
"I feel the need.... the need for speed!"
http://www.automotiveforums.com/img.php?313283teggie2.JPG
Old 12-29-2004, 09:37 PM
Kind of a Big Deal
ya, and if you REALLY dont want it to leak, they sell this sealer that you put on the outside of the pump where the pump meets the block, and it drys hard as a rock.... but u shouldnt need that if you do it right the first time.
