Old 12-29-2004, 02:01 PM
DukeMan's Avatar
DukeMan DukeMan is offline
TS paint to airbrush
Hope someone could help me out here. How long does the TS paint need to "gas out" after I´ve transferred it into a glass jar? I´m using the drinking straw method and I don´t plan to do the invert-can-prick-hole-pour-into-jar-messy thing.
Thanks,
/Fredrik
/Fredrik
Current Projects:
-´70 Camaro Z28 (Baldwin Motion hood wanted!!!)
-´32 Ford Roadster (on hold)
´69 Camaro thread
Old 12-29-2004, 02:46 PM
Veyron's Avatar
Veyron Veyron is offline
Re: TS paint to airbrush
I only give it a couple minutes, no problems.
Old 12-29-2004, 03:13 PM
freakray freakray is offline
AF Modelrater
A couple of minutes is fine, if you stand the open jar in some warm water while you wait for it to gas out, it helps even more.
Also, slowly stirring the paint once you've got it in the jar will help it gas out too, just be careful when stirring as if you are too enthusiastic it tends to bubble really quickly and 'boil over'.
AF User Guidelines
Old 12-29-2004, 03:20 PM
Veyron's Avatar
Yup stirring helps, I also thin it a little more with Gunze Mr. Color thinner which helps it settle down.
Old 12-29-2004, 03:21 PM
DukeMan's Avatar
That´s exactly what happened when I put the ice cold jar in tepid water, it boiled over quite dramatically a I had to clean the sink for ten minutes. But I don´t give up that easy and now all looks fine, I´m though a bit worried about heating up the jar again... Thanks for your quick answers.
/Fredrik
/Fredrik
Current Projects:
´69 Camaro thread
Old 12-29-2004, 04:10 PM
AF Modelrater
Well, I have the jar already standing in the warm water when I start emptying the paint into the jar and have never had it bubble over because of the warmth, only from stirring too vigorously.
AF User Guidelines
