Go Back   Automotive Forums Car Chat > Racing > Driving Style and Technique
Driving Style and Technique Got a favorite way to enter a corner? Discuss all things related to piloting a race car here.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-29-2004, 12:17 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Question When to shift?
I've never really figuired this one out.
I'm not sure exactly when to let my automatic shift. I've heard you're suppose to let it wind up as far as possible in each gear. But then I've also heard that anything revving past torque peak is lost power. So which is it?
My Grand Am's rev limiter is @ 5800 rpm. The torque peak is 4800 rpm.
So, when racing, should I just put it to the floor and let it bounce off of the rev limiter every time?
or
Ease up on the gas at about 5000 rpm so it shifts and then give it more gas when it shifts so it ends up staying around the torque peak?
So which is it - floor it, or try to keep it around the torque peak?
Thanks guys
Old 12-31-2004, 04:50 PM
Ridenour's Avatar
GranddAmnit
Re: When to shift?
PLEASE!!! ANSWER MEE!!!!!!!!!
RAGGGGGGHHHHHHHHH!!!!!!!!!!!!! lol
Old 01-01-2005, 11:50 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: When to shift?
letting it bounce off the rev limiter is just slowing you down and horrible for the engine. Through very thorough testing, its been determined that the fastest way to drag race an automatic is to just leave it in Drive with Overdrive off, even on automatics with "sport shift" features.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 01-01-2005, 02:45 PM
Ridenour's Avatar
GranddAmnit
Re: When to shift?
Ok good that's kind of what I was leaning towards.
And yeh you're right about the second part - I always put it in 3rd gear in order to lock out overdrive and it does a lot better.
Old 01-04-2005, 07:41 PM
buymeabmwm3 buymeabmwm3 is offline
Re: When to shift?
Check out http://www.cyberstangs.com/autocalc/...hiftPoints.asp
Pretty sure that fastest acceleration is achieved by running from torque peak to horsepower peak, and I think most cars' gear ratios are designed to reflect that fact. My car has the gear ratios spaced such that upshifting from the horspower peak drops the revs right onto the torque peak in the next gear.
1992 BMW 325i conv.
FOR SALE!!
IM me for more info. $6300 /obo
2005 Ducati Monster 620 i.e.
2005 Toyota Tacoma V6 4x4 Double Cab, TRD Off-Road - FINALLY HERE!
Horsepower is 100 ewoks poking you with pointy sticks.
Torque is one wookie pulling your arms out of their sockets.
Old 01-04-2005, 09:03 PM
RVMAN RVMAN is offline
Re: When to shift?
You're on the right track locking out OD. Next step is to have a shop "tweek" your tranny for more positive(i.e "hard") gear changes...also look into converter stall speed etc.
Old 01-08-2005, 11:55 AM
Ridenour's Avatar
GranddAmnit
Re: When to shift?
Ok all these replies sound good. Thanks guys.
Old 01-12-2005, 10:01 PM
AlienEvolution's Avatar
AlienEvolution AlienEvolution is offline
Send a message via ICQ to AlienEvolution Send a message via AIM to AlienEvolution Send a message via MSN to AlienEvolution Send a message via Yahoo to AlienEvolution
Re: When to shift?
Hey, how can you find out the Torque peak for your car?
"I have a Tundra '01 with 245k miles. Yes 245,000 miles. and only had to replace a lightbulb. This truck is bulletproof."
-ryba1000
Wurd.
Old 01-13-2005, 10:09 AM
Re: When to shift?
Usually listed anywhere you can find info on your engine. Do a google on your truck specs. Engines are described as having, for example, 200 hp@4000 RPM and 250 lb-ft@3000 RPM. The lb-ft # is the torque peak.
1992 BMW 325i conv.
FOR SALE!!
Old 01-15-2005, 02:17 PM
crzyCollegeKid crzyCollegeKid is offline
Re: When to shift?
i'm gonna talk as a honda guy cuz thats what i drive. i get my best times when i rev into the red line and shift right before i hit the limiter. but why? cuz even tho i'm not making much more power in the redline, when i shift, the engine still lands in the vtec powerband and doesn't bog down. you can't go by factory specs and numbers, unless you sit on a dyno in your own car, and then do some trial and error on the track. i know your question was about an auto tranny, but hopefully this will give you some insight. you have to try land as close as possible to your peak torque and horsepower when you shift, even if it means slightly overreving
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
Old 01-15-2005, 05:25 PM
AWP9521 AWP9521 is offline
Re: When to shift?
Some engines are like that, you should be able to feel it in the seat of your pants when the engine is beyond it's powerband, you know you have revved it too far when you feel the motor start to "lay down" and the trick is to get the shift off before that happens. It just depends on the design of the engine, some you can rev them right up to the redline and they feel like they will pull well beyond it and others will lay down before the tach gets close to redline and it seems like it takes longer for it to wind up that last 500 RPM or so.
I own 2 examples of what I'm talking about, I got an 89 Daytona Shelby with a 2.5L Turbo I engine in it, Redline is 6000 RPM but the engine feels like it starts to peter out at a little over 5000 RPM but yet has gobs of torque down low so if you shift at 4500-4800 the RPM drop is still in the meat of the torque band and the acceleration doesn't suffer. I also own a 94 Chrysler LHS with a 3.5L 24V engine, this engine has decent torque down low enough to spin the rubber but really doesn't come on strong til the tach hits between 4000-4500 (Probably like crzy's Civic) and then pulls real hard right up to it's 6500 RPM redline and even then it feels like it can go another 500 RPM or more but the tranny (Auto) electronics will not let it as you can have it locked in "L" and it will still shift right at redline on 1-2 and 2-3 upshifts then lowers the shift point to 5000 at 3-4 if you stay in it.
Old 01-16-2005, 06:22 PM
Ridenour's Avatar
GranddAmnit
Re: When to shift?
Hmm yeah more good replies. Yeah, from what you said AWP, I'd say my power band is definately about 4500 to 5500. I've been experimenting lots now, and If I let off at about 5500, and then gun it while it's shifting, I can effectively keep it in the power band. But if I let it wind past 5500, it's goes from "BWAAHHHHHHH!!!" to "waaahhhhh......" lol
and all the pull goes down the drain.
thanks again for all the good input guys.
Old 01-17-2005, 10:31 AM
Re: When to shift?
civic?!?!?!!? dude, that hurts.
not all hondas are civics. look at the sig
Not-named-yet:
R.I.P. Jessica
Old 02-01-2005, 04:33 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: When to shift?
drive, do a couple pulls in each gear, find where you engine begins to sit down and shift right before that.
Old 02-20-2005, 09:55 PM
op012503's Avatar
op012503 op012503 is offline
Send a message via AIM to op012503
Re: When to shift?
how can an auto tranny allow you to hit the rev limit????
Current ride is a 2000 altima 5 speed-Check it out!
http://www.cardomain.com/memberpage/755387
Closed Thread
