Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-29-2004, 10:36 AM
metallica21156's Avatar
metallica21156 metallica21156 is offline
97 eclipse
my sister has a 97 eclipse GSX with a greedy power extrem cat-back exhaust and a greedy hard pipe for the turbo. shes running about 15 PSI on the stock motor. it has a 5 speed. i was talking to a friend of mine and he said her car will get crank walk. is this true or does it only happen to some. she had the clutch replaced at 80,000 miles. she bought the car used so we don't know if it had been done before but the shop guy said it didn't look like it. she does have a stiffer shift into gear but its always been like that and hasn't gotten worse. so is she going to get crank walk or not. the car now has 102,000 miles on it.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 12-29-2004, 10:49 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: 97 eclipse
There are about a million threads on this already, but I will post it again. CW is not a common thing (although you may hear about it a lot). Your friend is an idiot. Any car can CW not just the 4g63's. Normally, if you are going to get CW you get it by 60k (although I have heard of one guy that got it at 90k. All in all, it is not common and nothing to worry about. If you are worried about it, take it somewhere and have them measure the endplay on the crank, that will tell you for sure.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 12-29-2004, 09:19 PM
Re: 97 eclipse
ok thanks. i'll try to go see if i can get her to have it checked.
